Question about Magellan MAESTRO 3100 98083401 GPS Device
Maestro 3100 touchscreen calibration off
The touchscreen positioning is off on my Maestro 3100. You have to press to the right of something to get it to recognize, and that proves almost impossible for items already on the far right of the screen. I have went through the calibration screen numerous times, done a complete wipe/restore, updated the firmware, even taken it apart to see if the ZIF connector or ribbon cable was damaged which they aren't. The screen isn't cracked or damaged in any way. Any ideas?
    Problem Solver:
  • 5 Answers
Try this update remember you need windows XP or it will crash or buy the CD for vista and windows 7 http://www.magellangps.com/support/notes.asp?supportID=537
Posted on Jan 06, 2010
Frozen screen on gps magillan
Posted on Jan 29, 2010
Bernina 770qe machine screen inactive. How do I recalibrate?
Alternative access to screen calibration:
- Access is achieved by simultaneously pressing the needle position buttons < > and switching the machine on.
- Select the cross symbols on the touchscreen for calibration.
Oct 27, 2017 | Bernina Sewing Machines
Can not calibrate the screen
Here is the procedure to calibrate the screen if you can not reach the calibration screen through the GPS menus.
Nuvi 2xx/2xxW Series: Turn the Nuvi off. Place your finger on the upper left-hand corner of the screen and then slide the on/off power switch to the left and hold until you see the calibration screen. Note: Some 2xxW models require the procedure below for the 7xx.
Nuvi 7xx Series: Turn the Nuvi off. Touch the screen anywhere and keep your finger there while moving the on/off switch to left (don't wait for Garmin logo to come up) and then quickly moving the switch the right (lock position). After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Now if you go through and press the dots and it keeps looping without saying "calibration complete" then the touchscreen has drifted out of specification and must be replaced.
Please see this link for more information about touchscreens and how to get it replaced.
http://www.sharc.net/gps_LCD_repair.htm
May 11, 2016 | Garmin nuvi 205 GPS Receiver
When I turn on my nuvi 200 it says press dot. When I press the dot it just moves around the screen to different location.
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position. Once unit powers on release the power button.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 09/30/2010
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Friend has a problem with his Garmin nuvi: when typing the letter to the left appears. what can be done?
It needs to be calibrated
To calibrate the touchscreen on your nuvi 200W follow the steps below:
Aug 14, 2010 | Garmin nuvi 200W GPS Receiver
Need help adjusting my screen. It is off by approximately 1/2 inch.
scroll to the user options menu, then system settings, then tap the next tab at bottom right, then go to the diagnostics tab, then touchscreen test and follow the instructions on the screen.
if you need further help, just post back to me
Bill
Jun 02, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Maestro 3100 will not change locations. I can be in Nashville, tn and it will have the screen on where I live in Ky.
the satellite are not linking up to your unit..
make sure it has a good charge, with the unit on press and hold the power button for 10 seconds after it shuts off. then press and hold the power button until it restarts.
take the unit outside in clear view of the open sky and let it aquire the saellites, indicated by the green bars in the top right of the map screen.
if they do not turn green, its not linking to the sats and you mgiht have another problem
let me know how you make out, so if it dont work, i can give you something else to try.
bill
Dec 22, 2009 | Magellan Maestro 4250 GPS
Cracked touchscreen if it repair on 3225 magellan maestro
You can fix, but the problem is it will cost you more money then you can go out and buy you a new one.
Dec 07, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My magellan maestro 3100 won't stay powered on
If the battery is fully charged then press the RESET button.
Jan 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Touchscreen
try calibrating the unit
Oct 17, 2007 | Pioneer AVIC-N1 Car DVD Player
Magellan MAESTRO 3100 98083401 GPS Device Logo
628 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
