Question about Casio MTP3036A-2AV Wrist Watch
Casio MTP3036A-2AV analog wrist watch
MTP3036A-2AV
How do you pop off the back of a Casio MTP3036A-2AV analog watch to switch out the battery?
SOURCE: Casio WS300B-1BV Wrist Watch
http://world.casio.com/wat/download/en/manual/
Punch in the 4 digit module number found on the back of the case.
Posted on May 04, 2008
Biggdex35
  • 333 Answers
SOURCE: Replacing battery in Timex wrist watch. When the ...
Toward the back case.
Posted on May 24, 2010
gemineye61
  • 831 Answers
SOURCE: How do I adjust the
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Posted on Aug 21, 2010
    • 102366 Answers
    SOURCE: AWS90D-2AV Wrist Watch: need manual for casio wave captor model 2556...
    http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2556.pdf
    Posted on Sep 29, 2010
    • 2501 Answers
    SOURCE: how do you set the
    you can get
    instructions from the Casio web site.
    Go to the casio web site "casio.com".
    Select "support" and the "manuals",
    watches;
    Accept terms
    Select "watch manual archive"
    Read the number of the back of your watch and enter it into the search box
    Posted on Oct 03, 2010
    Hi um my G- shock tells military time and i want to chain it
    If you haven't got instructions on how to do this, you can get
    watches;
    Accept terms
    Jan 08, 2011 | Casio G-Shock G611-2AV Wrist Watch
    How to change battery
  • Spread the towel out on a flat surface.
  • Remove the watchband if necessary in order to access the back of the watch.
  • Unscrew the back protector from the watch using the correct size miniature screw driver. Place the screws in a small pile on the towel. Be careful not to drop them as they are difficult to find.
  • Remove the back plate by unscrewing the small screws. There is a tiny spring on the underneath of the back plate. It may be visible, or not. Make sure not to turn the watch upside down or the spring will dislodge.
  • Remove the rubber protector to find the battery.
  • Use sharp point tweezers to remove the clasp covering the battery. There is a small hole at one end of the clasp. Insert one end of the tweezers into the hole to spring the clasp loose.
  • Remove the old battery with tweezers.
  • Insert New Battery and Reassemble Watch
  • Pick up the new battery using regular tweezers and put it into place. Do not touch the battery with your fingers.
  • Replace the clasp over the top of the new battery.
  • Perform a reset by touching the AC contact with one part of the tweezers and the back of the battery with the other part. Hold for a few seconds. Lift the watch carefully and look up at the front to make sure the watch is working. Do not turn the watch over.
  • Replace the rubber cover.
  • Replace the back plate by screwing the small screws back into place.
  • Replace the back protector by screwing the small screws back into place.
  • Reattach the watch band to the watch face.
  • Feel a bit unnerved by this? Find a local jeweler. Best regards.
    Jewel
    Sep 01, 2010 | Casio MTP3036A-2AV Wrist Watch
    How water resistent is watch??? Anyone with experience?? How about after battery replacement?
    mcdevito 75 here, Usually 50--100 meters of water resistance on brand new watches. However after a battery change, unless you also change the gasket (rubber ring) on the cover, you could loose all water resistance capability.
    May 28, 2010 | Casio AWS90D-2AV Wrist Watch
    I have lost the manual to reset the time on my MRP 700 Marine Gear Watch
    You can get instructions from the Casio web site.
    watches;
    Accept terms
    May 21, 2010 | Casio Marine Gear MTD1042A-2AV Wrist Watch
    I need an instruction manual for G-Shock G-601, Please
    you can get
    watches;
    Accept terms
    Apr 05, 2010 | Casio G-Shock G611-2AV Wrist Watch
    Had new battery now watch 4 hours behind CASIO WAVE CEPTER
    It sounds like your in the wrong time zone and day light saving is in the wrong mode.
    Sep 06, 2008 | Casio Wave Ceptor Atomic Silver Tone with...
    Backwards watch?
    if you just got the watch then I would take it back. Other wise you are going to have to send it in. None of the casio watches should run backwards. Call repairs and tell them what's going on. 800-706-2534 and then option 2.
    Jul 31, 2007 | Casio G-Shock G701D-2AV Wrist Watch
    Casio MTP3036A-2AV Wrist Watch Logo
    107 people viewed this question
    Top Casio Watches Experts
    Ansel Alberto
    Ansel Alberto
    k24674
    Are you a Casio Watch Expert? Answer questions, earn points and help others
