Question about Harley Davidson Road Tech HA90 MP3 Player
Ecm I have a 2007 flhtc and the bike started to run at high rpms at start up and stays there. No air leaks and IAC works
  • 91 Answers
Check throttle cables see if they are adjusted right (freeplay) at the small adjuster under the rubber sleve on the cable by the throttle if all is well, the cold start (choke on fuel injected engines)might be acting up and the dealer can fix that it needs to be recalabrated
Posted on Jan 03, 2009
On a cold start i have no high idle for warm up
coolant temp sensor and intake air temp sensor would be the next to check.intake air temp sensor is in the air intake tunnel between TB air air box. when running is there a DTC? by disconnecting the coolant temp sensor you put the ecm values at default try that if it corrects your issue replace it.(it will turn your check engine light on but you can clear later by disconnecting battery)
Dec 10, 2013 | 2005 Ford Focus
High engine idle about 2000 rpms
I would have it checked to make sure no error codes and then suggest only having the IAC it uses checked or serviced-----Idle air control exists in many drive by wire vehicles--have a physical throttle and or cruise control cable-----the start is Google this year model with IAC symptoms.
They get dirty or fail and all sorts of idle issues are possible
Nov 02, 2012 | 2007 GMC Sierra 1500
When i start the car it revs up to 2000 rpms or sruggles at around 200 or 300 rpms. After it warms up the problem seems to go away. Their is no check engine light on.
You have a vacume leak, and once the temp sensor starts to read after the warm up the ecm starts to control. I would also check IAC idle air control valve.
Sep 08, 2011 | Toyota Avalon Cars & Trucks
Thanks for the help, I now have tons of heat!!!!! But I have another problem with my truck, for the past 2 weeks now everytime I start it it wants to stall. I have to keep it reved at around 1500 rpms for...
I think your on the right track with the IAC but before you replace it it wouldn't be a bad idea to clean out the throttle body and the air bypass passage in the throttle body with some carb spray. The iac is located on the side of the throttle body and usually has a four wire connector plugged into it. It wouldn't hurt to remove the IAC and try cleaning it before you replace it. Sometimes they just get really gummed up.
Another thing that can cause this symptom is a vacuum leak.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jan 17, 2011 | 1993 Jeep Grand Cherokee
1995 chevy 4.3 idling at 2300 rpms
1995 S-10 Chevy Blazer just replaced fuel pump now it is idles at 1500 RPM's what should I do.
May 29, 2009 | 1995 Chevrolet S-10 CA Edition
With clutch pushed-in, RPMs start to go up to around 2000-2500
if it isnt the iac probably the pcv valve positive crankcase vent. it is on a vacuum line somewere under hood. or check the air cleaner, the hose with the small filter underneath the air filter. i take its fuel injected?
Feb 16, 2009 | 1987 Ford F 150
My car drives itself, revs high when in park to point of stalling
Bad or dirty IAC( idle control Valve) Romve duct work from air cleaner. Spray throttle cleaner or carburator cleaner with car running at about 1000 -1200 rpms . Aim straight at the IAC inside the throat of the throttle body. It is to the side of the throttle body . Try to aim at the hole and spary 10 seconds into the throttle body. Turn of the engine and let it sit for a few minutes. Then repeat the process. If that does not work, replace the IAC.
Jan 09, 2009 | 1985 Oldsmobile Delta 88
High rpms and then dies
check for loose vacuum lines or check to see if there cracks on them. you sound like you have a vacuum leak as well as your Idle Air Control Valve(IAC) going bad. good luck and happy holiday
Dec 22, 2008 | 1987 Honda Accord
Open Questions:
See all Harley Davidson Road Tech HA90 MP3 Player Questions
Harley Davidson Road Tech HA90 MP3 Player Logo
59 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
