Canon ir1023 error
Canon ir1023 won't scan to email, gives a result NG 0801 or 0802. It is on a network, can print to it, can browse to it with remote interface. Can't find what does the 0801 or 0802 means?
  • 1 more comment
  • HennoT Sep 24, 2008
    Same thing with Canon MF4690PL.
  • TrimmK Oct 21, 2008
    NG # 802
  • gav5 Nov 11, 2008
    The problem is teh same. Does some body know how to fix?
  • 111 Answers
SOURCE: Canon LIDE 500F scanner does not scan - returns error message about releasing lock switch, detaching interface cable and reconnecting
Check the lock switch and make sure it is unlocked. I think the lock switch is on the bottom...or it may be under the lid near one of the hinges. Flip it back and forth and leave it in the unlocked position.
If this doesn't work, then it will most likely need service. Contact Canon Tech Support.
Posted on May 09, 2008
SOURCE: Bizhub 350 error code EA3226 when trying to scan to email
I changed the SMTP address from a name to an IP and that resolved it for me.
Posted on May 28, 2008
SOURCE: Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Posted on Apr 20, 2009
SOURCE: Canon MP530 - Fax - ERROR TX Report - NG
Hi flyme.. I have the same problem but on an MF5770 all in one MFP. If anyone can solve this then wow.. I've been trying to find a solution for over 18 months now...
Posted on Jul 30, 2009
FixinFax
  • 3085 Answers
SOURCE: Getting Error TX Report: Result 'NG' - what does this mean???
It means No Good or Not Good, fax was never received for a number of reasons.
Posted on Oct 07, 2009
CANON PIXMA SCAN CODE 2,151,44
I have a PIXMA MP340 printer/scanner--prints fine but when I try to scan, it gives me error code 2, 151,44.
Nov 06, 2012 | Canon PIXMA Office Equipment & Supplies
I cannot send email from the D1180. We have a new Canon D1180 in the office attached to the network but I cannot sent email. I go through the steps and it looks like it is going to send it correctly but...
Not sure of the exact answer to the code, but make sure the SMTP or POP settings are correct so it knows what account to send them from.
Also If your network runs through a server make sure the correct user rights have been assigned to allow the printer to send.
Hope this helps Regards GM
Apr 14, 2011 | Canon imageCLASS® MF4150 All-In-One Laser...
Canon iR3235 will not print over the network. I can ping
Reboot the printer. ANd also try re-mapping the printer from your system.
Jul 09, 2010 | Canon Office Equipment & Supplies
Print activity report on my canon pixma mp830 and the result is NG.. trying to find what that means
NG only means the result is No Good. After the ng there should be an error number that tells what the problem is.
Nov 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon ImageRunner 2016 - scanner Not working properly
Ir 2016, can be onlly pull scanner, so that means that you must have installed scan gear, selected in scan gear, and over microsoft word or similar insert scan ( INSERT PICTURE FROM SCANNER OR CAMERA ), but the machine must be in scan mode, put original on platen or dadf, and then "pull it"from PC.
Hope that helped
pls.rate
Sep 30, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
Canon 6570 Copier Scan to a network file share, not email it
the easiest way to do this is to goto additional functions, address book, register new address, file, then you can type in the name you would like ie. Bill or Contracts. when it asks for the file path change it from ftp to smb and then select browse this will let you browse the network and just select till you get to your shared file. you can also type the ip address in the address bar of internet explorer and manually put the file path in the RUI under address book.
Aug 31, 2009 | Canon IMAGERUNNER 6570 Copier
I have a Canon ir 3045 copier, when I try to send the scanned copy directly to a file, the file doesnot save to the destination network folder. When I looked at the scanner send logs i saw status as NG...
I have a Canon ir 3045 copier. I had sucessfully scanned two documents but the third scanned document (107 pages) was not emailed to me. When I click on press details, the job type reads #801. how do i retrieve the document?
Apr 24, 2009 | Office Equipment & Supplies
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon IR C3100n copier "NG 853" error
I had a similar problem with my MF6540. I could access the remote UI and see that the printer was recieving information via the print log. It would list all of my test pages that I tried to print but in the print results column I would get an error code NG(##5536) and the printer would not actually print anything. I tried the UFRII driver stated above and everything seems to be working now.
Sep 17, 2007 | Canon imageRunner C3100 Copier
1,798 people viewed this question
k24674
jasbo
jasbo
