Question about Jenn-Air Refrigerators
I'm getting a wierd sound coming from my JBL2088HES refrigerator. It is a buzz like an electric shaver followed by a click. It seems to happen in 3 min intervals. Any Idea what it could be?
  • kevin_legnon Dec 10, 2009
    It does have an Ice maker and that was my impression, that the sound was coming from the Ice Maker.
  • magillago174 May 11, 2010
    is the sound coming from the back of refrigerator is the unit cooling does unit have an ice maker if unit is cooling fine then noise is not compressor related if you have ice maker the line to ice maker may have frozen or inlet valve may be bad the timing sounds like ice maker not getting water and cycling threw most ice maker have a heater two thaw cubes to harvest and then will cool back down 'you can hold your hand on valve to verify if that is the source or you can raise the metal wire at ice maker to off position or time and watch ice maker just before bussing noise to check if that is the source the fingers on the ice maker turn to go through cycle
    Problem Solver:
  • 11 Answers
Kevin,
It sounds like it could be the compressor overload relay or the compressor itself. Lets hope that it is the overload relay, most compressor replacements are very expensive.
The overload/relay isn't very expensive and replacing it will be cheaper than calling a repair tech to tell you if it is the compressor or the overload/relay.
This is a relatively simple repair, if you look at your compressor you will find two wires connected to a small box ( overload/relay )
To remove the overload first you must remove the metal retainer by unhooking it with a pair of needle nose pliers.
Now remove the overload relay by pulling it away from the compressor.
The relay for your refrigerator has a capacitor connected to it, the capacitor and the relay are sold as one piece part # 67005560.
all that you have to do is remove the old relay with the capacitor from the wires by pulling the plug off and connecting the new overload/relay/capacitor to it, reinstall the relay to the compressor and you are done.
Good Luck
Check us out at www.centuryappliancerepair.com
Posted on Dec 10, 2009
Refrigerator makes a buzzing sound for 10 seconds clicks and stops making the sound. This happens every minute or so
I believe that buzzing sound is coming from the start relay and the click is the overload clicking because the compressor is trying to start but cannot because the start relay is defective, You may have a run or start capacitor bad also, Thanks Sea Breeze
Model Number?
Nov 17, 2012 | Refrigerators
Won't turn over... just makes a clicking sound... and a wierd humming sound.
Try cleaning your terminals at the battery, even if not corroded. In my years as an alarm/radio installer I have come across this problem constantly, especially on GM vehicles.
Jun 21, 2012 | 1995 GMC Sonoma
GE Artica PSS25MGMB Stopped cooling/freezing, everything else works,lights, fans, just no cold and no compressor start sounds?
I would suspect the start relay and capacitor! With the clicks and buzzes, that is the most likely fault. Although you could replace one or the other of them, I always replace as a mated pair, because it seems that when one of them fails, the other one will fail shortly after. Items 733 and 734 on the following schematic (which also gives you an idea of what they look like and where they are located)
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-PSS25MGMBBB/0432/0165000/G1090005/00009?blt=06&prst=&shdMod=
Jan 13, 2012 | Refrigerators
Kenmore elite bottom freezer 3 yrs old. buzzes, clicks and hums, stops and resumes the noise, runs through that cycle 2-3 times each time it comes on. It works well, but seems to be keeping things colder...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Kenmore Refrigerators
Freezer compartment no longer cools. Continuous defrost cycle?
Good day,
Sounds more like the compressor trying to start and can't.
Pull the machine out, remove the rear cover and see if in fact the sound is coming from the compressor.
Apr 08, 2010 | Whirlpool Refrigerators
The freezer has stopped working and now the fridge is warming up! Seems to be coming from the bottom of the unit - it makes a buzzing noise followed by a click, as if it is trying to fill something...
Is the compressor (underneath the refrigerator) not running?
If so, the buzzing sounds like the compressor is trying to come on, and it won't for some reason. That's major repairs.
Oct 15, 2009 | Refrigerators
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
Odd sound
whoa gonna call - GHOSTBUSTERS !! I would start by replacing the light bulbs first. Has it always done this ? It dones seem odd. Maybe the switches are sticking. Do you hear a buzzing sound when you open the door? Where do you think the sound is coming from, the front or the back of one side?
Jul 11, 2007 | GE PSC25PSS Side by Side Refrigerator
Refrigerators Logo
883 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
