Question about Westinghouse LTV-32w3 HD Television
I have Westinghouse LTV-32w3 and the power wont turn. The blue light next to the power button on the side just keeps blinking so it seems to be getting power but nothing is happening. If anybody has any solutions please help.
  • 834 Answers
There is a blown capacitor in the power supply board the cap looks like a can and will have a domed top or puffed up on the top where it vented the vlaue of the part is printed on the side you cna , or have someone replace the cap or caps
and you should be good to go
Posted on Dec 10, 2009
Ltv 32w3 coax disabled
Google the model number with "manual" to try to locate the owner manual which if the set has such a feature (not likely) will tell how to unlock it.
My guess is set has a bad tuner etc and someone just wanted to dump it on you.
May 31, 2012 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have a Westinghouse LTV 32w3 HD LCD TV (LTV32w3HD)and it does not come on. I know it is getting power as when i unplug from the wall i can hear a noise.
hi;
its sounds like a loose solder or high voltage leak inside your LTV
if you know how to open the back cover or technical experience to troubleshoot
you can check the power supply board and inverter board if it has a loose solder
you can visualize it in the back of the board.
also check the wires connected to inverter boards if it has a leak.
or shorts.
Aug 28, 2011 | Westinghouse LTV-32w3 HD Television
No picture or sound light comes on for power up but does nothing
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look to see if you have any DC voltage at the output connectors.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LTV-32w3+
Please post back what you find
Dec 16, 2009 | Westinghouse LTV-32w3 HD Television
I am having problems with my Westinghouse LTV-32w3 HD TV. If flickers and rolls kind of like the old tube tv used to roll and you would have to adjust it in the back by turning the nob. I have a 37 inch...
The LCD controller is bad, after about on for 30 minutes, see sample here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notee: my pix show the board with the cover removed. You can run the TV with the back open and have s small fan blowing in the back to keep it cool.
You need new LCD controller (there are more than one version, you need to match with the LCD panel): http://www.shopjimmy.com/catalogsearch/result/index/?q=ltv-32w3hd&stock=all
Nov 25, 2009 | Westinghouse LTV-32w3 HD Television
Frozen picture and no button response
Hi John.
Try unplugging the TV for about 30 minutes to an hour (reset TV) to see if this fixes your issue. If it does not, leave the TV unplugged all night and see if it will operate normally. Hope this helps.
May 22, 2017 | Westinghouse LTV-32w3 HD Television
Westinghouse Model LTV-32w3 HD goes green with the look of a negative image intermittant. Comcast tech checked it on and off the box. Used our DVD player and same results. Bought it at the Moffet Field...
The "lvds" cable which is connected to the lcd controller board is taped to the backlight housing and is transmitting interference to the controller board. Remove the tape and pull the cable away from the backlight housing slightly. You will have to remove the mainboard to do this since it is underneath it. Do not touch the power supply or power supply connectors (dangerous high voltage).
Jan 05, 2009 | Westinghouse LTV-32w3 HD Television
Picture quality
I had the same problem before. I had my wireless router really close to the tv. I relocated the router, and the problem never came back.
Jun 05, 2008 | Westinghouse LTV-32w3 HD Television
Televison & Video Logo
267 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
