Question about Microsoft Xbox 360 Console
After usin Xbox 360 Red Rings of Death Fix, RINGS RETURNED! HELP!
I used the Red Ring of Death fix with the 8 pan head machine screws, rubber washers, and arctic silver paste. It fixed my xbox for the rest of the winter and summer. This Fall however, the freezing and the rings returned. Does anyone know what I could be doing wrong? I did notice the mother board didnt fit as nicely in the case after using the screws and washers.
  • tunebasket1 Dec 10, 2009
    Hey's for horses! Hyuck!
  • 3 Answers
Hey
Posted on Dec 10, 2009
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Rings of death
the "3 rings of death" or the so called "3 red lights" is actually caused by GPU overheating and mainboard flexing. When you need to do is open your xbox360 (warning, this will void your warranty) add more cooling fan inside your xbox360, you'd want to use 80mm fans coz they fit perfectly. you can fit up to two 80mm fans inside your xbox360.
Also, if you notice that your xbox360's mainboard is warped you need to fix this by disconnecting all the connections from the board. then place the board on a flat surface. then use a hair drier to heat the board and flat it out. its kinda complicated. hehe, at least you now have an idea on whats causing the 3 red lights...
May 01, 2009 | Microsoft Video Game Consoles & Games
Four red rings on my xbox
my xbox 360 has four red rings
May 01, 2009 | Microsoft Xbox 360 Console
2 Red Lights Xbox 360
You need to change the thermal compound.But if you have make sure you have 1 WASHER ABOVE THE MOTHERBOARD! 2 washers above are too many. try that and let me know how you got on
I had this exact issue 2 washers make the heatsink sit off the GPU Die. 1 allows it to touch the GPU DIE
Feb 12, 2009 | Microsoft Xbox 360 Console
Xbox360 rings of death red rings when i turn on the console. can you help?
If you only have two red lights that means your xbox is overheated I had this trouble and took mine out to the air compresser and blew massive dust out of it,It's been 2 months now no lights.
Jan 07, 2009 | Microsoft Xbox 360 Console
Ring of death on xbox360
turn it in to xbox. they will fix it.
Dec 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 2 rings
One red light signifies a major hardware failure or system error[4] , depending on which hardware failure or system error it is depends on how the problem can be fixed but in some cases there is no easy recovery and the console must be repaired or replaced. Two means the console is overheating and must be switched off and left to cool. Three, the infamous 'Red Ring of Death', means a general hardware failure and the console must be sent to Microsoft for repairs. All four red lights simply means that the console cannot detect its AV cable.
Nov 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 2 rrod
When you Ring of Death fix a 360 there are three types of screws on the bottom of the metal casing. Small black ones, short silver/bronze ones, and long silver/bronze ones. After your done X-Clamp fixing it, if you screw the short silver/bronze screws in too much, the screws ground the motherboard to the metal casing. Unscrew the short bronze ones a little bit and then try it. The 2 rings are a "False Overheat". I guarantee you, after you unscrew the short bronze ones that your 360 will not give you the error. Also do not put the small black screws in. They are not needed after you fix it. I wish you the best of luck.
Nov 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
103 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
