Question about Dishwashers
Dishwasher doesn't clean as well as it used to
Suddenly my dishwasher doesn't seem to clean as well as it used to. Lots of food particles show up inside and outside glasses, sometimes on silverware, often on plates & bowls. I haven't changed my detergent, how well I rinse off dishes, settings, or anything else. The water drains okay, so I would imagine that it's not a blockage of some sort.
  • 2 more comments
  • reevesp Mar 31, 2008
    I have the same problem. Worked great the first year, now food particles on dishes. No loud noises. Seems to be filling up and draining fine???????
  • Handyannie Apr 27, 2008
    I have the same problem - was working great for 1.5 years and now there are lots of food particles on glasses and dishes. I've looked to see if there is a screen/filter that needs to be cleaned but can't find anything. Both arms are spinning and water levels are fine.
  • Warren Griffin Mar 30, 2009
    I've recently posted a similar question (3/30/09). I have checked the spray arms - no holes blocked. Time to fill is short, so no blockage in fill line. The drain line is transparent so I can see there is no blockage near the dishwasher (and no food particles visible, but I had run the unit with no load and drained it a couple of times before looking) or near the sink drain. About 4 feet of the drain line is under the cabinets so I can't see it, but the low point appears to be right under the dishwasher, so would expect a blockage to be there, if anywhere. Also, flow during draining appears to be very rapid.
    The wash pump doesn't appear to be noisy and was replaced about 8 months ago. It was replaced to resolve the same symptoms I am now seeing and did, for awhile.
    The spary arms stop rotating within about 1/8 of a turn when I open the dishwasher during a wash cycle. Should they be rotating more before stopping? (In other words, are they rotating too slowly so they don't have enough momentum to rotate further when I open the door?)
    A technician indicated that there was an internal filter in the pumping unit that could be clogged but that it could not be cleaned. The pump unit had to be replaced. Is this true?
    I've recently posted a similar question (3/30/09). Ihave checked the spray arms - no holes blocked. Time to fill is short, so no blockage in fill line. The drain line is transparent so I can see there is no blockage near the dishwasher (and no food particles visible, but I had run the unit with no load and drained it a couple of times before looking) or near the sink drain. About 4 feet of the drain line is under the cabinets so I can't see it, but the low point appears to be right under the dishwasher, so would expect a blockage to be there, if anywhere. Also, flow during draining appears to be very rapid.
    Sergeant:
  • 236 Answers
Poss a blockage in the base hoses or try checking the spray arms for hole blockages. is the wash pump noisy?
Posted on Jan 20, 2008
How to remove large food particle trap in a electrolux dishwasher model # EWDW6505GBO
Good Morning Friend,
I understand you want to know how to remove large food particles that are trapped in your Electrolux dishwasher, model# EWDW6505GB0. First, I would suggest that you scrape away large pieces of food before putting any dish in your dishwasher.
Your dishwasher is equipped with a state of the art wash system. Periodically, the Glass Trap Filter and Large Food Particle Trap may need to be cleaned to maximize wash performance. The Glass Trap Filter is located in the center of the Large Food Particle Trap. The Glass Trap Filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in the Glass Trap Filter, grasp the handle, lift out, empty and replace. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Electrolux EWDW6505GS Fully Integrated...
Small food particles getting stuck
Check your drain filter and clean them. refer user manual for location
Apr 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher leaves food particles on dishes
You are not getting enough water in the machine. The inlet valve is probably plugged with sand or something of the sort. You will need to replace the inlet valve.
Jan 02, 2010 | GE Dishwashers
Food particles clogging up drainage system at bottom of dishwashe
Take it apart. Clean large particles of food off before placing in unit. You might try a little Clorox and wash at hottest temperature while empty first.
May 16, 2009 | Maytag 24 in. MDB9150A Built-in Dishwasher
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher throws food
check for filter on botton around pump and clean it
Feb 16, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishwasher is leaving food particles everywhere
Dishwashers need cleaning too :) Take a look inside your dishwasher: Click here http://www.appliancepartspros.com/partsearch/model.aspx?model_id=41284 then click on PUMP AND MOTOR diagram on the left. Number 47 on that diagram is a filter. Make sure that filter is clean. Then, using a dishwasher cleaner (see below) run your dishwasher through the entire cycle on empty. This should help, post back if it doesn't. Dishwasher cleaners: 1. Vinegar - good cheap solution, if you don't mind the smell :). Dump a gallon inside an empty dishwasher tub and start up the regular wash cycle. 2. CLR - I've been told it works, but never tried myself 3. Dishwasher Magic - This stuff works pretty good. One bottle per use. http://www.appliancepartspros.com/accessories.aspx?part_id=2675393&cat=62&rdr=%2faccessories.aspx%3fcat%3d62 Hope this helps, APP tech http://www.AppliancePartsPros.com
Aug 03, 2006 | Admiral 24 in. DWUA800AA Built-in...
Dishwashers Logo
639 people viewed this question
Top Dishwashers Experts
