Question about Toshiba Qosmio G35-AV650 Notebook
Display adapter fail i use a default monitor it only works 640x480 8 bit when nvidia geforge go 7600 is enabled
Looks like you have become a victim to the Video Burnout plaguing this series of notebook, I had the same issue, when Toshiba replaced the board it worked for about 3 more months then quit again. (this time outside the warranty) I'm looking for another working board to replace mine with. Good luck! it is cheaper at this point to replace the puter.
Posted on Feb 15, 2010
Where can I find a driver/adapter for Advent X19W LCD Monitor?
Goto device manager , uninstall the card. go into control panel and check that the driver is uninstalled from the programs list. Swich of the pc for a minute or two then reboot Windows updares does not download drivers for graphics cards so will not install or reinstall the driver that is causing the issue, 307? Users forget to uninstall from program manger in control panel which is why the card keeps reinstalling with the undesired driver.
Please let me know what happens
Dec 14, 2014 | Nvidia Computers & Internet
NVIDIA + BenQ incorrect resolution
Hello try to renew the graphic driver from here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Please choose the graphic card model in selection box.
Remember also to choose your windows system.
My advice is to uninstall all the the old software, before you install the new.
Try to change the screen resolution, when the installation is done.
Good luck
Mar 10, 2013 | Computers & Internet
I got recently a Packard Bell -Easy note TX86 ,my question is how can I choose between the Nvidia dispaly adapter and the Intel Display Adapter . Thanks, abraham.
Hi Abraham,
The best way to select an adapter is to connect the monitor/TV cable to the display adapter you want to use or you can go to the Display properties and choose the adapter to be used (you have option to make the display adapter Default).
Thanks and regards,
Anil.B.R
Sep 24, 2010 | Computers & Internet
My hp dv 9000 nvidia graphic is making the screen
Make sure you have set your screen resolution to the resolution that your monitor can display and the refresh rate is not too high. Try using default refresh rate and see if you will have the same problem, it fails try 60Hz.
This one works well on most monitors, CRT and LCD's.
Aug 24, 2009 | Computers & Internet
Microphone does not seem to be working
The microphone connector is on the rear of the monitor, and you need to connect it to your computer's microphone input jack. The cable is the same kind you would use to connect the audio output jack to the input on a set of computer speakers. Once the microphone is plugged in it works just like any standard microphone. No special drivers are needed for the monitor, but you do need to be sure that the proper drivers for your computer's sound devices have been installed.
If this solution has been what you needed, please take a moment to rate it. Thanks for asking here!
Feb 22, 2009 | Compaq Computers & Internet
Can't get pic back on my Lap top after using nvidia & ext monitor
disconect display,hold power button on laptop for 10-15sec and turn back on
Nov 10, 2008 | HP Pavilion dv9000z Notebook
Radeon X1300 - Windows has stopped this device because it has reported problems
As far as I am aware, you can not run an ATI card in the same system as an Nvidia card due to driver conflicts.
Oct 30, 2008 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Wrong plug-n-play display selected.
double adapter output display adapters generally need a multible monitor driver to run correctly,
see here http://www.nvidia.com/object/feature_nview.html
Oct 17, 2008 | Westinghouse L1975NW Monitor
Need help
You need to enter your motherboards bios. As the system starts up press the Delete key every two seconds. Hopefully you'll have video doing this. If you do not have video display. You'll have to remove the new video card for a short while. Again enter your bios. Still have your manual? If not click the link & download it here. http://www.foxconnchannel.com/EN-US/support/downloads.aspx?ProductModel=865G7MC-ES&TypeID=en-gb0000001
Enter Advanced Chipset Features
Goto pg. 33
On-Chip VGA (Default: Enabled). Disable this.
Init Display First (Default: Onboard/AGP) Change to AGP/Onboard. The AGP is to load first before the onboard.
Save & shut down the system. Clean out the AGP slot. There can be a dust build up from not using it. Canned air works well.
Leave the side case off untill your sure the 7600 is running correctly.
Get to know your board alittle. Read the manual a wee bit.
Good Luck! Enjoy!
please vote
Feb 15, 2008 | Foxconn (865G7MC-ES) Motherboard
Toshiba Qosmio G35-AV650 Notebook Logo
145 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
