Question about Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television
When i turn on my tv, several minuts turn off
    Brigadier General:
  • 3,917 Answers
Hi
Please check for any broken circuit inside the circuit board and try to fix it by soldering or any fuse that requires to be mended.
Thanks for contacting fixya.com
Posted on Dec 10, 2009
TV Turns off after several minutes ! needs to be off for several minutes before it can be turned back on !
Sounds like the Thermal safety cutoff switch is either faulty or it is working correctly and the printed circuit board is overheating. given that the TV is 12 years old it may be simply a build up of dust. If you are not confident in removing the units covers and giving it a clean yourself (unplug it from the wall socket first) then take it to a service technician. having said that, the cost of having it cleaned is probably more than the TV is worth given its age.
Apr 08, 2017 | Pioneer Televison & Video
Rca crt tv guide plus wont turn off for several minutes after turning on tv and dish. I have a satellite dish so removing the zip code causes picture to become snowy and whit horizontal and vertical s
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 17, 2014 | RCA F25432 25" TV
Samsung TV turns itself off every 10/15 minutes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jul 20, 2010 | Samsung TXM3297HF 32" TV
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
Mitsubishi WS 65513 turns itself off
Solutions?
Hope this helps
Jan 05, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Samsung TV will turn on and off several times, then stay on.
First, need to check the power bar(if you use).
then. if don't use power bar, need to check the power board.
Dec 12, 2008 | Samsung HL-R7178W 71" HDTV
Tv unexpectedly powers off
Hi i has the same probleme..... My tv has 1 years and 6month... since two days.... the tv turn off itself...I have just take 15minute, unplug tv, and i have open in the right side the little panel...And i have clean inside!!! And i have do the same thing with the big panel in the back of the TV...After i have clean the fan...After this clean my tv is number one... and nothing turn off
Apr 21, 2008 | Toshiba 42HM66 42" Projection HDTV
Tv turns off after several minutes
Hello, I would take it to a TV repair place, they will charge around $50 and let you know what the problem is with it. this is your cheapest way out, it you want to keep it. If you chose to take it please give me a fixya rateing. Thanks, Farren
Dec 23, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV Turns off and on
How long since the last time the bulb was replaced? It sounds like the bulb is overheating and triggering a safety shutdown.
It's probably in need of nothing more than a good cleaning (open it up, clean off the boards with a can of air) and *may* be time to replace the bulb.
Nov 13, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television Logo
87 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
