Question about White Rodgers 0754-1 Electric Water Heater Control
White rodgers motor turning heat not going thru
White rodgers motor turning @ thermo command...heat(water)
not going thru to room
  • 99 Answers
This item is a buy -out from Thermodisc send a inquiry to there contact us.
Link: Contact Us
Posted on Apr 07, 2010
Hi i have a wireless room thermostat i wish to fit to my potterton boiler can anyone advise me thanks
in general-
wireless thermo has 2 units - room thermo and furnace rcvr.
if thermo is battery powered no wires to connect - if not needs 24V connected - then why do they call it wireless?
rcvr connects to same 4 wires as current therm except at the furnace - 24v power and 2 control lines
I can't remember the color code except red/black is +24v/common
but I have found them messed up by "professional" installers so u need to verify before connecting or go by the terminal labeling.
Dec 09, 2014 | Water Heaters
Sequencer wiring
This manual provides specifications of the timers and contacts, and a description of the 3 types of contacts.
http://s3.supplyhouse.com/product_files/White%20Rodgers%20-%2024A34-6%20-%20Install%20Instructions.pdf
Mar 05, 2014 | White Rodgers Water Heaters
I have a HEAT MAKER MARK II Boiler and it wouldn't fire up , I replaced the HOT SURFACE IGNITER (I took the amp reading and i got 3.9 amps,wich is normal) and the boiler still wouldn't fire up i check...
Check the flow switch. Small black box lower left hand side as you face the from of the unit. Try to jump the connection and then see if it fires up. If it does, replace your flow switch. The flow switch prevent the boiler from firing because it is not sensing the water moving through the pipes. The boiler won't fire if water is not moving through it.
Craig @ Aggie Plumbing & Service
Dec 16, 2010 | White Rodgers Water Heaters
Burner lites but goes out after 2 or 3 min.
the white rodgers gas control needs to be replaced;
the way it works is: the thermocouple opens the pilot gas circuit and, holds it open
when it heats up by creating a magnetic field in the gas control then: when you turn
the knob on the gas control to "on" a valve inside the gas valve opens the main gas circuit and, electricity supplied by your RV keeps it open.
the main gas coil inside the gas valve is defective and, can not hold the main gas circuit to the burner open anymore.
Jul 24, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
How do you reset a white rodgers hot water heater?
The red button at the middle is the manual reset button.
Apr 24, 2010 | White Rodgers 0754-1 Electric Water Heater...
White Rodgers 0754-1 Electric Water Heater Control Logo
138 people viewed this question
Top White Rodgers Water Heaters Experts
Steve
Gene Haynes
Are you a White Rodgers Water Heater Expert? Answer questions, earn points and help others
