Question about Sony XM-ZR1252 Car Audio Amplifier
Turns off and on
The amp turns off and on randomly, it usually doesnt stay on for long, all the wires are tight, the fuses arnt blown ethier
    Sergeant:
    Champion:
  • 225 Answers
That has happened to me before. I switched to a thicker gauge wire and grounded it better.
Posted on Dec 23, 2009
Horn dosen't work
Check fuse. Usually located under the Steering wheel or under the hood. You will have to use the other side of the cover to determine which fuse controls the horn and see if the metal link is broken. If both are not blown its probably a short in the wire. If it randomly just happened then its a good first guess without knowing any further details.
Usually I check all my fuses any time I am looking for a specific one. Sometimes a random fuse can be the cause, and not the actual Horn fuse that is blown.
Jan 30, 2012 | 2005 Dodge Caravan
My lighting audio b4.250.2 arnt turning on
you burnt them by jumping cables
May 12, 2010 | Car Audio & Video
if u r in the Tallahassee,FL area,call 850-339-1130,we repair all name brands of car audio Capital Audio & Electronics Repair
Mar 19, 2010 | Car Audio & Video
My amp turns on and off about 2 second intervals what might cause that any help would be nice yours truly joey
1st, did the amp ever work correctly? If it did, disconnect the speaker wires on the amp. Does the amp stay on? If yes then you have a shorted or blown speaker. If no again disconnect RCAs, if amp stays on then check RCAs for cuts or pinches. If no then possibly a power issue. Check the battery wire fuse near the battery, and check the ground to the chassis of car. also make sure all terminals on amp are tight and no stray wires are bridging across terminals.
Feb 28, 2010 | Car Audio & Video
Why doesnt my 2400 watt amp turn on?
The size of the wire affects the performance of an amp, but the amp should still turn on. 12 volts is 12 volts. So you tested with another amp, on the same wires, and it works fine.The only thing you can really check on the new amp is the fuses in the side. If those are blown, then you should be able to (Unless the amp is fried, and that's why it blew the fuses in the first place) fire it right up. If the fuses arent blown, and you have all your power, and ground, and still nothing.. Well then in that case the amp is just bad, and regardless of the wattage, you just don't fix a Pyle amp.
Aug 08, 2009 | Kenwood KAC-8152D Car Audio Amplifier
Amp is on but no sound.....also amp stays on when car is turned off
sound is more like a speaker conection problem. than your amp. check your speaker connections first. to make sure they are plugged in all the way. and fit tight on the speaker. it they are . and it is still cutting out. you may need to trace the speaker wires. and see if they are getting pinched in the door jam. that is a usual culprit for speakers cutting out.
Aug 03, 2009 | Car Audio & Video
2 car subwoofers, one doesnt play
Short in amp ? try swiching wire's to speaker's around . if other speaker then work's , speaker's are both fine . if not , then short in amp , or blown channel in amp . get new one or find someone who know's more than i do about amp's
May 24, 2009 | Kicker CVR12 Car Subwoofer
My car amp is turned on but there is no sound
Heres a list of things to check
1.remote wire
2.RCA wires
3.speaker connection in and out of the box(Most Likely)
4.If all above fails check another amp with you head unit and make sure the head units rcas arnt blown.
Mar 19, 2009 | Car Audio & Video
Maytag 5500 AWW Turns off randomly shortly after starting
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt electronic components. If you have either... then you will need the the new motor conversion kit which includes the new motor, new motor control board and the wire harness. What you describe are signs the motor control board is nearing its end of life...
The kit takes about an hour to install. See www.neptunewaxmotor.com for disassembly photos so you can inspect the motor control board.
Sep 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Fuse keeps blowing when sub volume is turned up
the amp draw rating on the amp is 100 you need to put a larger fuse in, such as a 150 amp, it would be a good idea to go to 0 ga but not needed. you might also want to upgrade your altenator.
Nov 29, 2006 | Jl Audio 1000/1 Car Audio Amplifier
Sony XM-ZR1252 Car Audio Amplifier Logo
93 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
