Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
I have a Singer Futura 350. I keep getting an error code of "88" which says the machine isn't threaded properly. I've had & used this for nearly 2 years without issue. I've re-threaded many times and it still gives same error message.
It ended up being an airhead mistake... my embroidery foot had loosened and became crooked, causing the machine to think that the thread was hung up because the foot couldn't go down properly. Very happy that it wasn't an expensive fix. In fact, it didn't cost me a thing! Yea!!!
Posted on Dec 11, 2009
When I thread the bobbin, code 88 flashes, what is that?
Try zero your embroidery hoop carriage by off/on your machine before your next application, if no result disconect your embroidery unit and connect back again ensuring it is properly connected. Hope the problem can be solved.
Jan 17, 2014 | Singer CE-200 Quantum Futura Computerized...
Singer quantum futura ce200 - thread breaks
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 06, 2012 | Singer CE-200 Quantum Futura Computerized...
I have a Futura CE150 and error 19 keeps popping up but nothing seems to be wrong with the thread or bobbin thread
Jan 16, 2010 | Singer CE-100 Futura Computerized Sewing...
Singer Futura 350 bogus thread breaking error
I had the same problem for a LONG time. Yesterday I finally removed the top and the cover for the upper tension and found thread fragments under one of the discs. I removed it and used compressed air for dust clean out and it is working wonderfully. Good Luck
Aug 24, 2009 | Singer CE350
Singer Futura 350
Dear Wendy,
The E4, error message means the safety device is activated. Machine is locked up due to thread entangled with the bobbin case. Remove the needle plate and bobbin case. Check for any thread around the hook area. Also check your handwheel. It should turn freely. Good Luck
Jan 11, 2009 | Singer CE-200 Quantum Futura Computerized...
I am trying to do letter embroidery on my Futura 350 and I keep getting constant error messages about thread breaking even when there is no visible sign of that. Also, the bobbin thread side is bunching...
Check out your threading with "Machine setup" Tutorial under Help submenu and whether the thread tension control on the front panel is set to "E".
P.S. The error message about thread breakage appears not only when the thread is really broken but if the sewing speed is not changing smoothly (for example if design is not optimised).
Oct 06, 2008 | Singer CE-200 Quantum Futura Computerized...
Thread breakage sensor
Select in the main Futura menu Help->Machine setup Tutorial, lesson 10b, the balloon shows the proper position of the upper thread inside sensor checked area.
Sep 24, 2008 | Singer CE-100 Futura Computerized Sewing...
My machine is giving me an error 88 and keeps flashing fast when I turn it on.
I had that problem when the machine was not threaded correctly. I now floss the thread back and forth through the tension area everty time I thread the machine, to make sure the thread is in the right place.
Feb 15, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
360 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
