Hotpoint washing machine wd860 after 12 - 16 hours there is water in the drum why is this happening
    Scholar:
  • 49 Answers
Suspect water inlet valve is leaking when in closed position the valve is where the hose's hook up in the back unplug unit from wall to open top use a putty knife to push back small locks located just under top from front does not require much pressure to release top can see with flash light the valve is nomally held in place with two screws part most often has 3 wires 1common to both coils 1 for hot 1for cold if after valve is replaced verify hot and cold not reversed can always just swap hose's if wrong
to verify water coming from inlet valve and not another source can shut off water at wall for the 12 to 16 hours before replacing inlet valve
Posted on Dec 10, 2009
Hotpoint WMF760 fills but won't wash
http://www.how-to-repair.com/help/faqs/hotpoint-wml540-washing-machine-that-wont-start/
Aug 30, 2016 | Hotpoint Washing Machines
My hotpoint washing machine WF620, squeeks when it is washing and spinning
On most hotpoint wash machines you cant replace or grease the bearing you have to replace the whole drum which cost around 100 pounds from hotpoint and a couple of hours labour its a common problem on hotpoint machines.
hope this helps.
puggy
Jan 07, 2014 | Hotpoint Aquarius WD63 Front Load...
Our hotpoint ultima wmd960 washing machine timer stops with one minute remaining, but continues the wash cycle on 'a loop', and does not pump the water from the drum. We turn it off and then put it...
Have a look at this and check if your pump is full of things lost from pockets:
How to remove and clean your Hotpoint washing machine pump filter
However, I suspect the problem is really that something is causing the controller to (falsely) register an unbalanced load, and continually running the wash to try and redistribute the items.
Sorry I'm not sure what the fix is for that - could be motor tacho, or could be controller itself.
Jan 30, 2018 | Hotpoint Washing Machines
Hotpoint WMF760 wont fill with water..spin cycle not working either
replace the water inlet valve under the top cover from the manufactures website quoting the model nr eric
Jan 18, 2018 | Hotpoint Washing Machines
Hotpoint wmd 960 ultima,when press start button nothing happens apart from the clock starts count down to end of wash
if water starts but drum dont move.............
check the rear belt....if that is on then the motor needs new brushes............
easy fix ........... about £12 diy
cheers
Mar 22, 2011 | Hotpoint Washing Machines
Put my washing on at a 60 degree wash for 1 hour 40 mins. Went back to machine several hours later, there was tiny amount of water on floor and machine had water in it but the wash had not progressed any...
Sounds like a blockage perhaps the filter needs cleaning or pump blades jammed...If its a Hotpoint then filter is middle of sump hose connected to the drum....
Jan 06, 2011 | Washing Machines
Hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Open Questions:
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
