Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
I want to replace the old mercury termostat with new honeywell RTH2300B. I have only 2 wires. should I use W and R, is there any difference as which wire connect to R, which to W? I found that RTH2300B is not listed on honeywell website, is this a outdated model, I bought it today at HD.
I had the same problem. The two wires were old thread covered rather than plastic insulation. Looks like they used to be red and black. No color code on the baseplate. I called honeywell and the tech said connect to "R" and "W" and it didn't matter which wire went to which post.
Posted on Nov 04, 2011
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
R--red comming n the thermostat and white is heat going to the furnace!
Posted on Dec 21, 2009
I want to hook up a new Honeywell thermostat that has 8 wires in place of an old mercury one that had 5 wires
You just need to used that 5 wires. The rest you leave blank. Your new thermostat has stage 2 heat and cooling also 1 for reversing valve which you don't need.
Jan 06, 2018 | Honeywell Heating & Cooling
The other day, my lux 1000 thermostat panel has all digitalis symbols displayed, and could not control unit....installed a new Honeywell RTH2300B, this time no display, its blank.
did you turn the power off when you changed the stat? Do you have a c wire? Do you have 24 volts between the r and c???
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Dec 26, 2017 | Honeywell Heating & Cooling
I just purchased RTH2300B, Connected R w/R, G w/G, W w/W and Y w/Y left out Blue wire that is connected to Furnace on C. No heat comes out just cool air. Need help; frizzing
you the same person last night that posted .... my understanding is that you had a different type of thermostat originally with more wires on the old thermostat correct? from your post last night you have a heat pump system and this rth2300b thermostat is a straight cool straight heat thermostat... does it have batteries on the new one and does the new one not have a "c" terminal" post again what exactly was on the old thermostat color of wires going to what terminals on the old thermostat.. then tell me what you have for the new thermostat we can get you some heat... at worst case you should be able to jump out the red wire with the white wire at the thermostat and the heat should come on...you just will not be able to shut off without taking the wires apart but can get the house warm...
Jan 02, 2011 | Heating & Cooling
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Replacing a Williamson (White Rogers) Termostat
rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Jan 05, 2009 | Honeywell Electronic Programmable...
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Replacing thermostat
What is the blue hooked up to now?
Jun 07, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
929 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
