Just bought Panasonic TCP58S1 plasma. Problem is excess green. Normal and Warm color temp settings are horrible. I have to set to cool and turn down the color to get flesh tones bearable, however rest of color is washed out! What can be done?? Help! Thanks!
  • 834 Answers
If you just bought this new I would return it ASAP
Posted on Dec 10, 2009
Hi - we have problem with Viera tv. no sound or pic. switch on green light briefly. then straight to red light flashes 4 times then 3 sec interval then repeat. tv is just over 13 months old. any ideas.?...
Instructions Things You'll Need:
  • Damp Cloth
  • Fuse
  • TV Remote Control
  1. Ensure the power cable is securely fitted to a wall output if you can't get your Panasonic LCD TV to power up. Try testing the wall outlet with another appliance to make sure there is not electrical fault with the outlet itself. If there is still no power, a blown fuse may need replacing.
  2. Switch off the color correction option if you are using HDMI cables and the displayed image has unnatural colors. For instance, if a picture area that should be red is blue or green, then the color correction option may be the issue. Press OK on your remote control. Now access the Other Adjust option and scroll down to the Color Correction option. You can now turn the setting off, which should restore normal image quality.
  3. Press the Mute button if you can't get your Panasonic LCD television to produce sound. This may have been pressed in error, cutting off the sound. Check the volume settings on any other devices, such as a games console or DVD player, that are connected to your LCD TV. If the volume is set to low on such a device, it can limit the sound output on your TV.
  4. Check that the air vents at the lower rear of your Panasonic LCD TV are free of dirt and debris. Dirt can accumulate in these areas, causing the cooling function to under-perform. Panasonic LCD sets come with built-in safety features that shut off the power if your set becomes too hot. Clean the air vents with a damp, rather than wet cloth. Dust and vacuum the room regularly to prevent the problem from recurring.
Jan 24, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic PT-56LCZ70 T.V. works fine but the picture is red. Any ideas why?
If you mean the picture has a red cast to it you can go into your setup mode and change teh color temp setting to normal or cool. It sounds like it is set in the warm mode which adds more red to your picture.
Apr 29, 2010 | Panasonic PT-56LCZ70 56" HDTV
I want to know the perfect color settings for the th-42px80u
The Settings are :-
-Picture menu Picture mode: Custom
Picture: +80
Brightness: +60
Color: +44
Tint: -8
Sharpness: 0
Color temp: Warm
Color management: On
x.v.Color: Off
Zoom adjust: [grayed out]
-Advanced picture submenu
Video NR: On
3D Y/C filter: [grayed out]
Color matrix: [grayed out]
MPEG NR: [grayed out]
Black level: Light
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 10, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic TCP58S1 has no pic. or sound. Red light blinks 9 times.
It's dead. 9 Blinks means the display adaptor is dead. If it's still under warranty, you're covered.
Jan 22, 2010 | Panasonic Viera TC-P58S1 58 in. Plasma...
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
Try to adjust it in the Service Alignment Mode (SAM).
Jan 04, 2009 | Philips 26PF9966 26 in. LCD Television
Setting Color on TV
Hi Amber3,
I would recommend reading the information available on Panasonic's website. There are links for Frequently Asked Questions (FAQ) which may be helpful.
The manufacturer's website lists in their FAQ the Panasonic plasma TVs include an enhancement feature for blue and green colors, and instructs how to turn the feature off if needed. Visit http://www2.panasonic.com/webapp/wcs/stores/servlet/vSupportFAQDetails?idval=UCM_PRD_CNT_001993&pagetitle=FAQs+for+Plasma+TVs&contentType=FAQ#tv17 to see what Panasonic recommends.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Color has too much red
Is this happening when you are switching between color tempature (Normal,Warm, and Cool). You wont be able to access it in normal menu.
You will have to accesss the service tech menu. enter "062596 then info", if u enter the code correct at bottom of screen you will see a warning menu only access by a service tech , continue in menu you will see on main option screen "alignment" enter this. Go to white point adjust the three temp settings (Normal, Warm, and Cool) settings as follows.
Color Temp. I Red I Green I Blue I
Cool 122 120 121
Normal 125 118 108
Warm 127 110 75
( These are factory specs u can tweak them to your own perference)
After u set these press left on remote and exit back to main service menu and store these setting before turning TV off set these settings
I see this alot when Philips manufactured the TV. The did store the settings.
Jan 22, 2008 | Philips 50PFP5332D 50 in. Plasma...
Recommended best settings for the TH-50PZ700U Plasma TV
Try this one and see if you like it!
Normal: No
Picture: +22
Brightness: +9
Color: -3
Tint: 0
Sharpness: 0
Color temp.: Warm
Color mgmt.: Off
C.A.T.S.: Off
Zoom adjust: (grayed out)
PC adjust: (grayed out)
-- Other adjust menu
Video NR: Off
3D Y/C filter: Off (grayed out)
Color matrix: HD (grayed out)
Block NR: Off (grayed out)
Mosquito NR: Off
Black Level Light
3:2 pull-down: On
HD size: Size 2
Dec 26, 2007 | Televison & Video
Televison & Video Logo
361 people viewed this question
Top Televison & Video Experts
