Question about IBM ThinkPad T22 2647 Notebook
Thinkpad 600e 2645
When I boot the laptop, the power lights will come on for a short time but then the computer will not boot up. All the power lights will come on but then just the first yellow and the last green wil stay on. I have replaced the battery.
Thanks
David
  • 1 more comment
  • dkk3000 Jan 21, 2008
    How do I remove the ram (where is the ram) and clean.
    Thanks
    DKK3000
  • Anonymous Jan 22, 2008
    I tried cleaning the ram but still have the same problem. When it starts, the lights on the computer will come on for a short time and you can here the fan start, but then nothing. I've even tried hooking up a external monitor but still nothing.
  • dkk3000 Jan 23, 2008
    How do I either check, replace or repair the system board.
    Thanks
    Scholar:
  • 94 Answers
That model is an older IBM, the CMOS Battery may be dead by now. That has been my experience.
Try this - replace the cmos battery first.
The settings may not be able to be read. So laptop don't know what to do after P.O.S.T.
Posted on Jan 28, 2008
    Novelist:
  • 123 Answers
This can be caused by:
1.The monitor is not connected properly.
2. Bad hardware
Verify that the monitor is properly connected in the back of the monitor as well as to the back of the computer.
If the connections are OK it means that monitor or the video card is probably damaged. To test which component is dameged connect a different monitor to your computer or connect your monitor to a different computer.
If the other monitor works on your computer it means that your monitor is bad and if your monitor works on another computer it means that you probably have a damaged video card.
                           or
Ensure that all cables are correctly connected and pushed in firmly. On some systems the mouse and keyboard connectors are very similar and next to each other. Ensure that the mouse cable is plugged into the mouse socket and the keyboard cable into the keyboard socket
Check that system unit are plugged in. Check the power socket by plugging in a lamp and ensuring it works
Check that there is power to the system unit. If you are unsure or do not know how to check this, either change the fuse or borrow a suitable lead from a colleague
Switch the PC on, watch to see if the keyboard lights flash and the fan is blowing air out of the back. The hard disk light should also flash on and off during the start up process.
If the system beeps several times when powered on carefully count the number of beeps - some systems use this to indicate the sort of error that has occurred, but remember that some computers produce one or two beeps as part of the start up process.
I you hear an unending series of long beeps, which usually means your mobo is not seeing the memory sticks properly. A short series of one long and three short beeps usually indicates a problem w/ the graphics card. Taking mem sticks and/or gfx card off and resetting them, with some contact cleaning if needed, generally solves the problem, provided, of course, none of these parts are damaged.
Don't forget to unplug the power cord before removing/inserting the memory and video card, otherwise you might end up killing them.
Let us know how things turn out and don?t forget to rate the posting.
Posted on Jan 27, 2008
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Jan 27, 2008
    it will solve your problem,good luck.
    Scholar:
  • 132 Answers
Hello, the symptoms your describing sounds like a bad system board. Can't say in all my years of repair have I heard of "cleaning" RAM, but I guess you never know. This model is known for its "weak" system board. You can find more info on that on IBM's site.
STP162
Posted on Jan 22, 2008
  • 49 Answers
If you are hearing beep codes you can repost it here... anyway probably the problem is not in your power options... try removing your RAM modules and use an eraser to clean contact points the use a non-static brush to clear the dirts of the modules... securely firm the RAM and try booting up you unit...
rank me if this helps...
Posted on Jan 20, 2008
  • chris albert navarro
    chris albert navarro Jan 22, 2008
    turn over your laptop you will see a small screw... the smallest one i think.. just pull it out and it got a door like cover....
How to remove the password bios for laptop ibmIBM ThinkPad 600E 2645 PC Notebook
It can be done but it requires some electronic skills.
Thinkpad laptops -To remove Power on Password and BIOS passwords, please click on this link and follow the instructions.
http://www.fixya.com/support/r4335050-remove_bios_power_password_thinkpad
Sep 08, 2011 | IBM ThinkPad 600E 2645 Notebook
Thinkpad 600E won't boot from disk
Set the boot order to boot from cd drive first, to enter the bios ...
With the unit powered off, hold the F1 key and power the unit on. Keep F1 held down until Easy setup appears.
Jul 17, 2010 | IBM ThinkPad 600E 2645 Notebook
IBM Thinkpad 600e (2645),error 189 and could not installing win98
Usually this means a hardware failure. I would suggest reseating the CMOS battery overnight to reset the system. Also you might want to replace it as well. It could also be more serious such as a motherboard component failure.
Also IBM error code # 189 according to Scott Mueller's Upgrading and Repairing PC's (8th edition) - "Excessive incorrect password attempts." Is there a password on your CMOS ?
Also try hitting ESC key on boot to bypass. Good luck!
Sep 23, 2009 | IBM ThinkPad 600E 2645 Notebook
On a ibm 600e, how do I boot from a cd? I'm
ok go to the bios system by pressing esc or F12 or F2 key when the computer restart. After that change the boot sequence. CD drive first after that HDD or follow the instruction that are given by computer in bellow or side, after configure just press F10 for saving.
Mar 14, 2009 | IBM ThinkPad 600E 2645 Notebook
Ibm thinkpad 2645 600e
if you got a windows xp cd then boot from it and format the drive then reinstall xp
Dec 09, 2008 | IBM ThinkPad 600E 2645 Notebook
IBM 600E 2645 won't boot from CD rom
You can go into the BIOS and change the boot order of the drive devices,change the CD as the 1st boot device.
OR
As the laptop boots up, press F12, this will allow you to select the CD as a boot device.
Dec 07, 2008 | IBM ThinkPad 600E 2645 Notebook
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad T22 2647 Notebook Logo
169 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
