Question about Marvel 6BAR-BD Beverage Cooler
Marvel 6BAR light does not illuminate. The bulb
Marvel 6BAR light does not illuminate. The bulb is OK and before not lighting for a period of time the light would dully illuminate then extinquish after about 5 seconds. Is their possibly a relay that went bad and requires replavement?
    Novelist:
  • 101 Answers
More than likely your socket has a bad connection (probably the ground). There are two switches that can send the socket power...the door activaed switch and the manual override (ON/OFF button in the toe-kick). If you turn on the manual switch and the light is steady, then the door switch is bad. Otherwise I would trace out the connections on all the switches and on the back of the socket.
Posted on Dec 20, 2009
Testimonial: "Thank you for the expert analysis!"
I have a marvel 6bar under counter beverage cooler that stopped working.
Need to check the motor circuit I think there was a problem with the motor
Oct 20, 2018 | Heating & Cooling
Marvel 6bar te doesn't turn on
turn wheell manually first
Jun 20, 2014 | Computers & Internet
When headlight are on and hit the beake pedal only the 3rd brake light comes on the rest are stuck . When i release brake pedal it seems like i am driving with my brake light on . but my headlight off...
It may sound silly, but check your brake light bulbs to see if they have been installed incorrectly. Brake light bulbs have two filaments, one for tail light, and a brighter one for brake lights. On some cars if the bulb is installed wrong, the brighter filament will stay on for tail lights. The only other thing I can think of is the wrong bulbs have been installed.
Dec 25, 2010 | Toyota Camry Cars & Trucks
Marvel undercounter refrigerator, works for a few days then stops
I experienced same problem with my refrigerator, Marvel ar61. Call Marvel and they will send you a repair kit which includes a new thermostat, switching relay and a new thermistor. My refrigerator is working great.
Mar 28, 2009 | Marvel 6BAR-BD Beverage Cooler
I have Marvel 6bar beverage refrigerator that suddenly stopped cooling- any suggestions on how to fix- I am trying to avoid paying a couple hundred dollars for repair thank you for your time
If light work but not running at all, then change the temp control (thermostat). If compressor and condenser fan motor are running but not cooling, then you have sealed system problem
Dec 01, 2008 | Marvel 6BAR-BD Beverage Cooler
Marvel 6bar-bd gets too cold - explodes soda can
I also have the same problem. Our Marvel 6BAR runs continuously until the beverages freeze. A technician came out and replaced the thermistor under warranty. It was a simple repair that anyone could do. This solved the problem for about another 18 months, but it has returned. I will now search for this part and do the repair myself. It only takes a few minutes to do.
Aug 30, 2008 | Refrigerators
Marvel Cooler/Fridge Light Not Working
It sounds like the bulb is not getting power. There is a door switch that turns it off when the door closes...this may be stuck. There is usually an optional (depending on age) ON/OFF switch that overrides the light to be on full time. If the light will also not turn on with that switch then there must be a disconnected or broken wire either going to the light switches or going to the light socket from the switches. I hope this helps.
Aug 30, 2008 | Marvel (6SBARBSG) Wine Cooler
Marvel 6BAR stopped cooling
The dip switches define the temp range. You have it set to the warmest. Try moving the next dip switch to move the range cooler.
Jun 23, 2008 | Marvel 6BAR-BD Beverage Cooler
Marvel 6BAR-BD Beverage Cooler Logo
301 people viewed this question
Top Marvel Refrigerators Experts
Marvin
Marvin
ray gallant
deton8 von Splosion
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
