Question about Insignia 2.1 Speaker System (3-Piece)
My problem just came up recently. The speakers keep losing the bass and having nothing but treble coming out of the speakers. I checked all of the connections and they're all fine. This happens for about 10-30 seconds but it happens around 1-3 times ever 5 minutes so it's very annoying. What's the best way to fix this? And also I checked all the speaker settings on the computer and they are all fine as well.
I just got that same problem too. Except its completely gone with the bass not coming back. I think it has to due with wiring because the speakers have not gone dead and there plugged directly into the outlet.
Posted on Jan 06, 2010
I have a samsung LHB655NW surround sound system. The four corner speakers are double units with one above the other.the top ones work but no sound comes out of the lower ones.
If you are talking about the driver cones in each of the units, then it's odd that they should have gone, unless they have driven too hard or damaged (say by a child poking them). Double unit speakers have a crossover built into that separates the sound into treble and midrange or bass.
If the sound coming out is "treble" the high frequency that shows the bass units are not working.
Make certain all the wiring is good to the speakers and if you can see the bass speaker check it is not damaged.
If you need to, go inside the units and connect a 1.5 battery across each speaker terminal for a second. If it "pops" then it's working.
May 07, 2018 | Samsung Audio Players & Recorders
How do i find out what sound card my p.c is using? i'm on windows vista, and need to change the bass and treble level ?
Most laptop sound card do not have a setting for bass and treble.
You can use external powered speakers that have bass and treble settings and connect these speakers to the headphone socket on your laptop.
Jun 26, 2012 | Computers & Internet
Sub woofer far too basey relative to treble- appears to have no means of adjustment
You can adjust the bass (and treble) of all sounds coming from the program you are using. For example: WinAmp; Click View -> Equalizer and adjustments can be made from there. I believe the lower frequencies (your bass) starts on the left and continues to get more treble and less bass the higher the frequency gets (farther to the right).
But most programs should have some form of an equalizer. Which can be accessed slightly differently in all of them.
Without more specific knowledge on this one it is hard to give more detailed instructions on this. If need please let me know and I will follow up with a how-to for your operating system and/or specific program you are using.
Jun 08, 2011 | Altec Lansing 221 Computer Speakers
Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have...
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
Mar 17, 2011 | Audio Players & Recorders
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
I've got a 1999 ford expedition with the Mach radio system in it and it does not have any bass playing thru the front or back speakers and i've changed out the factory amp thats in the back where the sub...
does the new amp you have have a hpf setting if so check to see if thats on, turn off the x-over so it will play both lpf and hpf, bass and treble. are all the speakers wired to the amp aswell, this is the only thing that would stop bass other than the head units settings.
Jun 21, 2010 | 1998 Ford Expedition
Bass hits when i play the radio but not when i play a cd
Dont assume because you have set the bass and treble options for your radio that they will work for your cd, press the source button until you come to cd and then set your bass and treble again, hope this works
Dec 19, 2009 | Car Audio & Video
Can't adjust bass and treble
The only adjustments available on the unit are Volume and Bass (Subwoofer Level). There are no Mid-Bass or Treble adjustments.
Sep 20, 2009 | Jasco GE 98903 2.1 Speakers
Pioneer deh 5800mp receiver
Bass and treble settings are adhusted only when u r in custom setting of equilizer mod.in any predifned mode u cant change the bass and treble settings.
Dec 30, 2008 | Pioneer DEH-P5800MP CD Player
Logitech r-20 speakers
Hi again andrew63,
There are two possible methods of adjusting the bass and treble output to your Logitech R20 speakers:
1. Hardware - if you feel like experimenting or working with electronic gadgets, you can connect an external preamp with tone control or graphic equalizer between the PC and the input of the speakers/amp; and/or (probably the easiest)
2. Use a software (to listen to your music files/medium) that has a virtual equalizer such the old MusicMatch Jukebox or as an add-on/plug in.
Btw, thanks for asking me to be a Tech Buddy.
Jan 22, 2008 | Acer AL2016W 20" LCD Monitor
Insignia 2.1 Speaker System (3-Piece) Logo
100 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
