Question about Nikon FA 35mm SLR Camera
Nikon Fa advance lever loose. Not used camera for a few years and set to M250 mode due to not having batteries, Advanced lever once to test, advanced one, then pulled lever back for another test. Lever then feels lifeless and has no resistance to being moved. it will not take a picture even with batteries. any Idea what the problem is?
  • theflyinggar Dec 11, 2009
    Depressing the motor drive shutter release button and Turing the motor drive coupling works sometimes, but once you've done it and you take another picture you get the same problem again, probably should get a repairman to look at it.
    thanks for your suggestion
  • Mehdi Esfahani
    Mehdi Esfahani Nov 03, 2013
    u saved my life
  • 667 Answers
Try moving the coupler on the bottom where the motor drive would connect. See if you can rotate the piece clockwise. With the advance lever loose, it may be in mid-cycle on the winding/advance
Posted on Dec 11, 2009
Testimonial: "Depressing the motor drive shutter release button and Turing the motor drive coupling works sometimes, but once you've done it and you take another picture you get the same problem again, probably should get a repairman to look at it. thanks for your suggestion"
Minolta 700 film advance lever was working, then it wouldnt wind, now it is stuck.
Use or buy a brand new battery from store that sell lot of them.
Do not get from store that only has a few, meaning they have been sitting there for years.
atdlee@netzero.com
Feb 14, 2014 | Minolta X-700 35mm SLR Camera
Nikon fa advance level fell off
I can tell you that you can't fix it yourself
Mar 07, 2013 | Nikon FA 35mm SLR Camera
Film was in camera, frame 18. Batteries had failed at frame 17, had to depress "B Lock" button" and set shutter to 60 to release shutter. Replaced batteries with fresh batteries, battery...
This camera is somewhere between fifteen and thirty years old. It is highly unlikely that spares would be available, and it would be extremely expensive to have it repaired in any case, most artificers familiar with the internal layout having probably retired years ago. Maybe the camera should be retired too ?
Apr 16, 2017 | Olympus OM-4TI 35mm SLR Camera
My FA camera shutter release button won't work, no reaction when depressed and look through the view finder was dark.
The dark viewfinder usually means that the battery must be replaced as the mirror has fully or partially locked up. A new battery usually fixes this instantly. The stuck shutter release can also be due to a failed battery or is due to the shutter lock being engaged. The lock is disengaged by pulling the film advance lever back slightly.
You can download free instructions for your camera courtesy or the Norman Butkus website; if you find his information useful then consider making a donation as he suggests toward his site running costs.
The battery is either two SR44's or LR44's, the latter are cheaper but give less accurate exposures due to their unstable voltage output, but if you're shooting on negative film instead of transparencies you'll be unlikely to spot the difference. A single CR1/3N battery also does the same job as two LR44's but is harder to find and more expensive than two of the very common LR44's.
Feb 18, 2011 | Nikon FA 35mm SLR Camera
My Nikon FE film advance lever is stuck. It does not move at all, there is no film in the camera. The repair shop wants $100 to fix it which is more than the camera is worth I think. I would like to do...
Have you tried fresh batteries and setting the shutter speed dial to M90 or m250 whichever you have? If this does'nt work you can remove the camera bottom plate and gently pull a lever away from the advance cog. Some times things get out of sync in there. Sorry I can't be more specific but I did this many years ago. Good Luck.
Dec 12, 2009 | Nikon Photography
Nikon fm10 cannot get shuuter release button to depress or film advance lever to work. is there a lock on shutter release ?
The film lever is also a switch. If you had advanced the film lever, **** it outward a little. You will feel the detent click somewhat when doing so. Leave the lever outward and see if the shutter will work. The detent is for appling an closed circuit for the light meter. When the lever is fully pushed back in it shuts the power to the meter on off to conserve battery power
Oct 13, 2009 | Nikon FM10 35mm SLR Camera
Not letting take pics or advance film
Check the batteries first. The electromagnetic shutter requires power to function. To free up the shutter and advance lever, rotate the command switch to "M90" (if I recall). That should re-set the shutter and allow you to advance the lever mechanically.
Jul 04, 2009 | Nikon FG 35mm SLR Camera
Canon A-1, film advance lever and shutter release
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Jun 24, 2009 | Nikon FA 35mm SLR Camera
Nikon FA will not advance. Meter will not give reading.
the capacitor is bad or the circut has a fault somewhere. You will need to take it to a camera tech or just use it in the manual moide only
Jan 14, 2009 | Nikon FA 35mm SLR Camera
Coolpix 2200/3200 Battery Compatibility
The Coolpix 2200 / 3200 camera is designed to use 2 (two) AA type batteries. Due to Nikon’s advanced power management technology, two standard AA Alkaline batteries can provide more than 100 photographs. For better performance, please consider using Nikon EN-MH1 rechargeable batteries. These are available as an optional accessory at Nikon dealers and at The Nikon Mall Recently a new type of battery, the CR-V3, has been released to the market from several battery venders. The CR-V3 is similar in shape to two connected AA batteries and easily fits in your Coolpix camera compartment. Nikon has confirmed compatibility only with the following battery brands. Please use one of the following brands when using CR-V3 type batteries. Duracell Sanyo Panasonic Due to it’s unique design the Eveready Energizer® brand CR-V3 battery may not be compatible with the Coolpix 2200/3200 camera.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Nikon FA 35mm SLR Camera Logo
383 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Steve
Are you a Nikon Photography Expert? Answer questions, earn points and help others
