Question about Frigidaire FAC126P1 wall/window Air Conditioner
Blowing cold air instead of the heat
The unit has started blowing cold air instead of heat
  • 534 Answers
Heater coil has possibly burnt out. his coil is located rightr behing the front coil of the a/c You need to pull the unit from its sleeve and look inside behind the a/c coil and there it is. It looks like the inside of a toaster the elements should be incased in a metal box. What causes the burn out is 1 poor air flow over coils due to dirty filter or dirty coil, 2 dust build up, the minute particals the get through the unit 's filter and build up over time causing burnout, 3 possible high limit switch on the coil housing itself. This switch prevents the heater from overheating and causing a fire. Have this look at by a tech the cost incurred isn't really that much.
Good luck on your repair hope this helped
Dave
Posted on Dec 11, 2009
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Heater blowing cool air
Is it set on summer switch which is the fan running all the time blowing cold air
Feb 15, 2012 | Heating & Cooling
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital...
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital temperature on the climate control is not correct. When it states that it is below 30 degrees on the ext and it is warm outside the air wont be cold. Once it starts going above 30 degrees the air gets colder. Today the blower stop working all together. Was told it maybe the climate control unit was bad. You can hear the door opening/shutting when you switch the temp from cold to hot. But there was no heat blowing out whatsoever in the winter time. Could you please give me your opinion on whether or not it is the climate control unit or something else?
Jul 11, 2011 | 2000 Pontiac Grand Prix
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Fan runs backwards forces flame to blow back into heater instead
cracked heat exchanger not cheap replace unit ur motor just doesnt change rotation on its own
Jan 13, 2009 | Reddy Heater RLP100 Portable Forced Air...
My Carrier 58dxc is making a loud noise
If your turning on heat and the unit is knocking and blowing cold air, your compressor is having problems in heat mode, could be reversing valve. A tech is needed in your situation. Getting the prob fixed right away will save you dollars..
Dec 02, 2008 | Heating & Cooling
Unit blows cold air instead of warm (burrrr)
FAULTS ARE STORED WITHIN THE CIRCUIT BOARDS MEMORIE TRY UNPLUGGING IT FOR 2 MINUTES AND PLUGGING IT BACK IN
Nov 23, 2007 | Amana PTC153B50AJ Electric Heat Air...
Frigidaire FAC126P1 wall/window Air Conditioner Logo
325 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
