Question about Epson Stylus Photo 1280 InkJet Printer
Epson 1280 Printer breakdown
Up to recently it printed perfectly. Then upon switching it on, all three red lights and the one green light started blinking, printer does not move or make noise.  Nothing to do with computer or software, checked this, nothing to do with USB cable, checked, no paper jam, ink is there, Note: this printer had a fliuduc ink delivery system by Lumijet added, it has worked fine with it for at least two years.
  • 26 Answers
It is the wasted ink pad, they are full.
to have your printer work again
turn off the printer.
press and hold the ink and paper button while turning on the printer, wait for 5 seconds then release the button and press the paper button for at least 10 sec.
if done correctly , you will see the carriage start moving
Posted on Jan 21, 2008
6ya staff
SOURCE:
3 lights blinking upon starting Epson L200
if the three lites, two red (1 paper jam and second ink tank) ligts and one green light is on. than what is problem in printer please how can solve this problem easily.
Jun 13, 2012 | Epson Office Equipment & Supplies
Green power light is flashing and red light next to it stays lit
A flashing green on printer light generally means its waiting for a command for instance, push print, stop etc... also check that the pause button has not been pushed. if so depress again to release printing process
Jul 11, 2010 | Epson Stylus Photo 1280 InkJet Printer
The green and red lights are on.They arent blinking just on.And when i go to print a job nothing happends.
The green light is the power light, the red light indicates out of paper or an empty ink cartridge.
Dec 05, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 red ink low light will not go out. Have tried replacing both ink cartridges and have disassembled the unit and cleaned the waste pads. I have tried the reset sequence posted on here but it...
Epson color 777 Printer isn't working, the print light is on, but so is the red error light, ink jets are filled, had that confirmed, plenty of paper, what's the problem?
Jan 16, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 -alternating green red flashing lights
you could use it for a table top computer archeological relic. the flashing lights will attract peoples attention, and start conversations at parties.
Mar 23, 2008 | Epson Stylus Photo 1280 InkJet Printer
Printing problem
You have either a clogged colour print head or a non-functioning print cartridge (only one colour working). If the printer has separate cartridges for different colours (and black) you can do a partial swap, replacing the ones that have failed, but start by running the command CLEAN PRINT HEADS from the printer options or controller panel, and watch for the quality to improve. You may have to clean the heads two or three times. If no change in the quality after two flushes, replace the cartridges with new ones.
Good luck...
Nov 16, 2007 | HP DeskJet 610c InkJet Printer
Epson Stylus Photo 1280 InkJet Printer Logo
379 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
