Question about Brother IntelliFAX 4100 Laser Fax
I have a panasonic fax machine. It will receive
I have a panasonic fax machine. It will receive faxes fine but when I try to send a fax, I hear the phone ring and the other line answered but it doesn't ever show it connects.
Memory full
Posted on Dec 15, 2009
  • 622 Answers
If this is to every line then you have a bad main board or your ringer waiting period needs to be increased... (meaning the amount of times it rings before pickup...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 10, 2009
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
I'm unable to receive or send faxes
Are you sure the line is good? You can try a plugging a telephone into the line to check it.
If you press the "hook button" (or whatever it is called on that machine) do you hear a dial tone?
is the phone cord plugged in snugly and in the proper jack on the machine? Is the cord good?
These are a few things to try.
If all of that checks out, then the phone board on the machine is shot.
May 26, 2009 | Panasonic PANAFAX UF-6000 Fax
CAN'T SEND OR RECEIVE ANY FAXES
HI.when u try to receive or send any fax.fax gives any msg r not.first check ur telephone line.u have to connect it in line.there are two places in fax .one is ext and second is line.check it u r putting it line.for receiving check auto answer .put it on fax only mode.u will receive fax.MIAN AKHLAQ.if it helps rate the solution.
May 16, 2009 | Panasonic KX-FPG381 Plain Paper Thermal...
Cannot receive faxes
Hi:
I quick way to really determine if the line could be a problem is try dialing your fax from another phone ,like a cell phone and just listen. What do you hear, noise, a recording, or do you hear the squelch tone that your fax machines should be putting out. If not then the line could still be the problem. Also if you recently switched to a DSL line then you should get a DSL filter and install it inline on your fax line. Also does your fax ring like it's trying to pick-up? If so, do you have the reception mode incorrectly set to TAD or manual mode.
Good Luck
Andrew
Mar 16, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Fax can not be send and received
press the monitor key...you should hear a dial-tone...if not try below.
Check the phone line with a regular phone plugged into the wall jack.
Mar 11, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Model - Fax Machine Panasonic KXF-110
it would cost as much to have a technician replace the ADF motor as a new fax machine.
Feb 04, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Sending Faxes
there is no need to change the setting.just feed the document to be sent and dial the number of the recipient.after hearing the fax tone press enter key
May 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
KX-FL511 Panasonic Fax machine will not receive document
Try going through menu and turn ECM to no or invalid also try adsl filter on incoming line
Feb 27, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Can't receive fax but can send
Call your cell phone from the fax machine and check the caller ID to make sure that it is the correct number for your fax machine. Next, call the fax machine from you cell phone, and make sure the fax machine rings. Problems like these are almost always a phone line issue, not the machine.
Don't forget to rate your solutions please.
Dec 03, 2007 | Sharp UX P200 Plain Paper Thermal transfer...
Can not send faxes, but can receive them
this is for the uf 7000 you need to do an all job clear on the machine to try and fix your problem, sounds like a memory lockup
Oct 02, 2007 | Panasonic PanaFax UF-7000 All-In-One Laser...
Brother IntelliFAX 4100 Laser Fax Logo
76 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
