Question about Gateway Computers & Internet
Can I install sp0802n hard drive with windows xp home ed. on an old gateway essential 550. from the requirements I think I can not sure about BIOS
    Genius:
  • 1,584 Answers
If you do instal it you will find the mobo specs different from the machine it came out of and will require a reformat of that drive or it will not load properly.
Always best to reformat a drive prior to putting in another machine.
Posted on Dec 11, 2009
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
I have a windows 98 system bios and i wish to Put a differnt Hard drive in that has windows xp on it . Is there a way to do this
Hi
It probably won't work. Win 98 machines not only had older BIOS but also the processor was older and most importantly the video was older. XP may just not be able to recognize these parts. In my lab I use an old Dell laptop that was made specifically for Win 98. I was able to install XP but the graphics stay in four color mode as there were no drivers ever written for XP. Also the hard drive with XP was probably formated using NTFS while Windows 98 (unless modified) only recognizes FAT. Good luck and sorry
Mar 05, 2010 | Gateway Essential 400 PC Desktop
Downloaded window 7 on my netbook and forgot to backup before installing i had xp
Sadly, there is no direct upgrade path for XP (pro or home) to Windows 7, only Vista. Windows 7 from XP requires a clean install.
Still, check the hard drive and see if Windows 7 moved the files to another location. It installs differently from XP or Vista and there may be a chance they are still somewhere on the drive. Use the search feature to look for a known file and see what happens.
Dec 06, 2009 | Gateway LT2021u Netbook
Wont load correctly
check the hard drive.western digital hard drives work good in this computer. ihave two of them.also windows xp home works good on this.or run the system recovery cd.lastly' re do the
windows installation.
Jun 03, 2009 | Gateway Essential 400 PC Desktop
Formatted hard drive, now can't install windows xp home ed sp2
Enter BIOS and restore factory default settings.
Try again with the XP install.
Regards B.
Mar 22, 2009 | Dell Latitude D600 Notebook
Windows XP installation
Make sure you back up any important files on that gateway machine before you install Windows XP Home because you may lose some during installation. You definitely will lose files if you chose to format the hard drive during your installation of XP which is recommended. After you backup, everything should be a breeze.
Dec 30, 2008 | Microsoft Windows XP Home Edition
Old gateway essential 400c PC
yes, a 400 mhz processor can run windows xp, but you will want to have a LOT of ram. i would not recommend it unless you have at 256-512 or more ram.
windows 2000 can get along with 128-256 ram.
Sep 20, 2008 | Gateway Essential 400C SE PC Desktop
I have two operating systems on my hard drive.
You can manually disconnect the IDE/SATA cable temporarily from your motherboard (the one with NT PRO & XP HOME), then you can cleanly install a Windows XP on your new Hardisk. And after installing, you can re-connect the other hardrive on your computer and format it under your NEW Windows XP, be sure to set the BIOS BOOTUP sequence that you boot on the right drive.
-mrsolution
Jun 11, 2008 | Gateway GT4022 PC Desktop
MyBook 500GB Home Ed hangs WinXP SP2 boot up process
Thanks to Guest above. I was having the issue with USB of my WD drives causing the system to hang upon boot up. Disabling USB Legacy did the trick. It's only my WD externals that were causing me the issue but no mor
Jan 24, 2008 | Western Digital My Book Essential Edition...
Hard disk partition table error
Insert windows xp bootable disk and boot your system in CD/DVD and then reformat your HDD and install new windows operating system.
Jan 08, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
