Question about Sony Xplod XM-554ZR Car Audio Amplifier
How should i arrange the wiring on my xm-zr1852 xplod amplifier to get the best performance out of my 12'' audiobahn subwoofers?
  • David S. May 11, 2010
    What is the impedance and power rating of your subwoofers?
    Novelist:
  • 150 Answers
It depends on the impedance of the subs-if your subs are dual 4 ohm coils then you can parallel the coils which will give you 2 ohms per sub- you could get max performance from your amp by just wiring the 2 ohm speaker load to each channel of the amp which will hit them with about 200 watts rms each. another way to do it is to wire the coils in series which will make each sub an 8 ohm load and then parallel them together and that will show a 4 ohm load -which you can use to run the amp safely in bridged mode. This will give you exactly the same amount of power to your subs as in 2 ohm stereo will. so with your amp being 2 ohm stable in stereo or 4 ohm stable in bridged mode- those are the numbers you want to hit for maximum"safe" operation
Posted on Jan 16, 2010
The speakers just pulse when you plug in the rca jacks pn a sony xplod xm-zr1852
Depending on the amp, you may have a bad ground on the rca's. The best way to determine if you have a bad rca ground it to run a wire from ground to the outside ground of the rca. If it stops pulsing, you have a bad rca ground in either the amp or the head unit (radio).
Apr 07, 2014 | Sony Car Audio & Video
I got Sony Xplod XM-ZR704 700W 4/3/2-Channel Car Stereo Amplifier and 12" sub. it play good for continuous 2 hours but after that starts tripping and goes on off. i checked all wires and connections.
Amp is probably over heating. Make sure the ohm load of speaker is good for that amp. This amp is not really built to handle a bridged 2 ohm load. Make sure ground wire is clean and tight to the body chassis.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 18, 2012 | Sony Xplod XM-ZR704 700W 4/3/2-Channel Car...
Can i have box dimentions for my 12" xplod sub
  • Warranty Terms - Parts 1 year limited
  • Warranty Terms - Labor 1 year limited
  • Product Height 12"
  • Product Width 12"
  • Product Weight 7.8 lbs.
  • Product Depth 6-1/2"
  • Subwoofer Size 12"
  • Resistance (Ohms) 4 ohms
  • Bottom Mount Depth (inches) 10"
  • Woofer Composition Mica-reinforced woven glass fiber composite
  • Woofer Surround Rubber
  • Peak Power handling 1300W
  • RMS Power Range (Watts) 380
  • Cutout Diameter or Length (inches) 12"
  • Sensitivity 84dB
  • Frequency Response 30Hz - 1kHz
  • found at:::---- http://www.bestbuy.com/site/Sony+-+Xplod+12%22+Single-Voice-Coil+4-Ohm+Subwoofer/9202481.p?id=1218057724056&skuId=9202481
Jun 04, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
I have 2 xplod 1000 w amps an 2 rockford 15inch power dvcs but the ampsare different models one is a XM-ZR1852 RB an one is the XM-2165 GTX. will both the subs sound the same if i hook up 1 amp to each...
Yes, power is power. If they are truly rated at the same output power into the same impedance then all you have to worry about is the crossover frequency. If those are not the same then they will sound different.
Dec 24, 2009 | Car Audio & Video
How to install Sony Xplod XM-1652Z Car Audio Amplifier
First you will need to post the # of voicecoils each subwoofer has, and their resistance.
Next - you can purchase an amplifier installation kit just about anywhere that will supply you with everything needed to wire up 1 amplifier.
Power wire w/fuse
Ground Wire
Remote Wire
RCA cables
Speaker Wire.
CLICK HERE for your manual.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 21, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Can I run 8 speakers and 1 sub through 1 1200watt 2:1 Sony Xplod?
asuming the 8s are 4ohms each; wire two in series and that gives you 8ohms then two more in series then you put those together in parallel and it gives you a 4ohm load. repeat with other four for the other side. you should then be able to bridge the sub
series; posative of one speaker to negative of other speaker and that doubles your ohms
parallel; posative to posative negative to negative and that cuts the ohms in half
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Xplod XM-DS1600P5 red light
For some reason it has gone into protection mode to limit further damage to the amplifier. Remove the subwoofer wires and power on to eliminate shorted voicecoil. After checking all wires for continuity to ground, a service tech will be required.
Nov 30, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Sony Xplod XM-554ZR Car Audio Amplifier Logo
316 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
