Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP 6210 - since last week fax Doesn't work. Everything else works ok.
    Sergeant:
    Champion:
  • 277 Answers
Check that the [hone line is pluged in
Posted on Dec 10, 2009
Will the HP 6210 work with VOIP and Win 7?
HP Officejet 6210 All-in-One is not tested on VOIP connections when it was in manufactured. However these printers do work with VOIP connection.
If you are unable to get the printer working on VOIP connection, there are few ways to fix this.
1. Reduce the Fax speed of printer ( from Setup - Basic Fax Settings - Fax Speed ). Try to Fax
If this does not work, try the step below
2. VOIP is Digital technology and HP 6210 works on Analog Signals ( standard telephone line )
- You need a DSL Filter which converts the Digital Signals to Analog and vice versa. This filter is available at any departmental store or computer accessory shop
- Connect the DSL Filter to phone socket. Connect the printer telephone cable to Analog port of DSL Filter ( to Line 1 Extn port of printer )
Either of this should fix the solution. However there is another solution which may or may not be possible. It is to reduce the baud rate on your Cable connection ( though not recommended )
Regards,
Shawn
Jan 28, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Just want to know how to print the fax log?
Please find the below steps to print fax log for Officejet 6210 all in one.
  • Press Setup , and then press 2 . This displays the Print Report menu.
  • Press the Right arrow button to scroll through the following report types:
  • Fax Log: prints a log of approximately the last 30 fax transactions.
  • After the desired report is highlighted, press OK .
Regards
Riztech
If this solution is helpful,kindly vote 'thumbs up' and testimonial.
Dec 31, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I have a rather generic question- should I expect a home/office all in one machine to last more than a couple of years. I do a moderate amount of printing. And should I expect to be able to print...
in simple - NO - No machine is built to last anymore. My experience is genrally between 18 and 24 months is about the life of this tyoe of machine and even if it is still going at that point the inks will become so expensive it is wioth changing anyway
Jul 12, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Fax Failed - Test Failed- Hardware Failure
had a lightning storm since? if so the modem in it may have been hit. i recommend pluging all devices into a electrical strip/surge strip to help prevent that. could be something else, but get back to us if you had no lightning around since it worked.
Aug 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Outgoing Fax on my HP Officejet 6210 All-In-One
The fax machine needs to hear a dial tone first to send a fax. If you have no fax number, what working phone number are you using?
Jan 23, 2018 | HP OfficeJet 6210 All-In-One InkJet...
Cannot scan anymore. The scanner works but the page is blank. I can copy, fax or pring without any problem. It is a HP all-in-one Officejet 6210
Many known scanner issues of this model by HP.
Most likely uneconomical to repair.
I've tried to fix dozens of these models, but the problem comes back in 2 weeks.
Sep 07, 2008 | HP Office Equipment & Supplies
Scanner doe not work,fax and print are ok
first re-install product driver properly then try.
Jun 03, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Printer Problem
will not install because of problem with print spooler
Jan 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
I can't fax... Hp 6210
Have you tried to contact your phone line provider? Maybe the is on thier side. If there is nothing wrong with their conncetion then pls click on the link below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&cc=us&lc=en&dlc=en&product=421991&dlc=en&lang=en
If this doesn't help your issue, pls post here and I'll get another solution for you.
Oct 18, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
