Question about Singer Sewing Machines
I own a Singer Futura CE-150 embroidery machine. The needle is always breaking. It is the right kind of needle I check and re check how I put it in. Very frequently the bobbin will get all wound up. I put that in right as well. I don't understand what is going on! Why does my thread keep getting caught breaking my needle, and sometimes tearing my fabric?
  • 323 Answers
SOURCE: BOBBIN SLIPPING AND STOP EMBROIDERY
First,call the technician and see if he will honor a warranty on his repair work. Next, sew on the machine until it messes up again. Do NOT take all the stuff loose. Take the machine, the garment, the thread,everything just as it is to the technician. Don't even lift the presser foot. He will probably find the problem.
Usually, on a problem such as this, it is the wrong bobbin, the bobbin inserted the wrong way, the tension not working , not threaded correctly, a rough spot on the bobbin case or the bobbin case is not properly positioned.Some times the thread jumps out of the thread take up lever.
sewman7
Posted on Aug 28, 2008
SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Posted on Nov 17, 2008
sweetpea53
SOURCE: while sewing on singer quantum
Mine did this and it seemed impossible to fix. My problem was a tiny bit of thread stuck in the bobbin cover (but it could be anywhere in the thread route). I ran dental floss through the path the thread follows and also in the bobbin cover and poof out came a small piece of thread that all my looking missed. Hope this helps.
Posted on Dec 28, 2008
  • 10 Answers
SOURCE: the bobbin thread shows
This may or may not help, but perhaps you should check that your bobbin is wound correctly, and that you have it inserted into the bobbin case properly. I find that these are usually the 2 main reasons why the bobbin thread show through.
It could be the design, does it do it on all designs?
Posted on Nov 05, 2009
  • 64 Answers
SOURCE: I have a Singer Futura CE-150 and it keeps
Either upper thread is not passing through thread sensor area or sensor is broken.
Second possible reason is that if design is not optimized the sporadic speed change provides thread breakage error even if the thread is not broken physically. Make sure your software is updated to optimize it automatically (Futura main menu->Help->Live Update).
Posted on Dec 22, 2009
Why cant i install futura ce 150 softwRE with windows 10?
Singer Futura CE-150, I NEED HELP!!! - FreeEmbroideryStuff ...
freeembroiderystuff.embroiderydesigns.com/forums/threadView.aspx?id...
Jul 11, 2014 - 15 posts - ‎10 authors
I just got the Singer Futura CE-150 and every time I start a design it ... Posts: 2/10/2014 11:18:44 PM, RE: Singer Futura CE-150, I NEED ... Futura CE-100but didn't realize it didn't have its original install cd with ... I can't afford Singers price. ... -Software-Download-and-Installation_A287.aspx?id=287&siteid= ...
Singer futura ce-350 software download - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesJavaScript isn't enabled in your browser, so this file can't be opened. Enable and reload. ... Singer futura ce 150 embroidery machine 3900 designs dvd. Top 3 singer ... Singerfutura software for windows 10 memphis soft portal. Using my singer ... Singer futura software installation for windows 2000 xp youtube. Service ...
Singer Futura CE-250 Sewing and Embroidery Machine w
SINGER® FUTURA™ Software Installation for Windows ...? 7:20https://www.youtube.com/watch?v=RDkHyrh0ejkNov 30, 2009 - Uploaded by SingerSewingCompanySINGER® FUTURA™ Software Installation for Windows 2000 & XP ... yes i already have a singer ...Singer Futura will not work with Windows 7 - Microsoft Communityanswers.microsoft.com/.../singer-futura.../da1ea4db-8594-4a12-91d1-d8...I bought a Singer Futura sewing machine and a Win 7 laptop for Christmas. ... can find the right person at Singer to talk to they might let you have a pre-release version of thesoftware. ... What if you download the patch and it still doesn't work? ... if you are using ce-150 go to http://futura-support.com/downloads/ce150.html.
Dec 30, 2015 | Sewing Machines
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Singer quantum futura ce200 - thread breaks
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 06, 2012 | Singer CE-200 Quantum Futura Computerized...
The bobbin case on my Singer CE-150 embroidery sewing machine pops out when I am embroidering. What's wrong
It must not be inserted right, check your manual and if you do not have it handy, go to singerco.com and download one for free. You can cause real damage if it is loose, so be careful that something isn't broken and not letting it seat right.
Sep 11, 2010 | Singer CE-200 Quantum Futura Computerized...
What embroidery download formats can be used on singer ce200
It depends on your software version. The list of supported formats could be found in the manual, on Futura support site or checked right through the sofware menu (File->Open, File->Save as)
Apr 28, 2010 | Singer CE-200 Quantum Futura Computerized...
The needle constantly breaks while embroidering. I tried every type of needle with no difference. It goes ok for a few seconds till the needle goes down and hits the foot and breaks. I do have on the...
Sounds like your tension is too tight and the thread is pulling your needle. Also, make your that you needle position button is on center. If it is on left or right it will cause your needle to snap.
Apr 19, 2009 | Singer CE-200 Quantum Futura Computerized...
Needle breaking-CE 250
I had that same problem and it was due to the thread being too tight. Put the thread net on your thread and it should be ok.
Dec 22, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
146 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
