Question about Hannspree HW191D LCD Monitor
Switches on shows screen and then goes off - Hannspree HW191D LCD Monitor
My monitor is doing the same thing. I think it does that when its cold. I turned the monitor off, shook the screen and turned it back on and it was working.
Posted on Jan 04, 2010
    Scholar:
  • 34 Answers
If you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,
then .... (from a.n. other)
after two weeks searching I finally find doctor living stone
http://www.aplusperfect.com/articles/lcd_capacitor_repair
more fun with paulbtorrent
the takening the case bit off is like open your wallet a second time
after buying a new LCD, but you must! smallest two screw driver's flat headed, practice using two pennies stuck together()with your fingers after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!]
also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new one do go burst! you have to laugh really, what next , a new on/off button, as you work though the whole inverter ! come back all is not well
mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmm
Posted on Feb 04, 2010
  • paulbtorrent
    paulbtorrent Feb 09, 2010
    The lcd has three parts the screen plate(windows)/the logic(vga)/the inverter(power plug). Parts that go are the backlight ccfl's, behind the plate, and parts of the inverter, ie capacitors, all three take a bit of power from the inverter. The self test check that all the lights are ok and the inverter is ok, else it switchs off, ie if 3/4 light work it will switch off(my own case), hence the on chech error then off, However sometime there are stages of on/off ie on/ but no screen display, if that is the case the following may be of help...if you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stonehttp://www.aplusperfect.com/articles/lcd... more fun with paulbtorrent the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flat headed, practice using two pennies stuck together()with your fingers after, one little () move and inch and {} again, with the case , it does
    not break, just need to lever open [once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace
    all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new one do go burst! you have to laugh really, what next , a new on/off button, as you work though the whole inverter ! mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not
    wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from another a.n other)Generally, if the screen went out quickly, it was the
    inverter. If it went out over a slow period of time (flickering etc..) I
    would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order ccfl and replace and going
    cheap and see if I can get away with fitting a 15" in my 19' as it a
    1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.
    http://www.lcdparts.net/howto/troublesho... OR MONITOR
  • 225 Answers
Make sure the resolution for the computer is ok with your monitor and also make sure you set the right Hertz for the monitor. Try switching them around a little bit and see if that helps and makes it stay on.
Screen shows correct image then goes black. if monitor switched off then on proper screen shows for a second then black again.
problem related to lcd lamp supply
just replace the power supply(called inverter board) connected to the lcd panel lamp
Jan 21, 2011 | Hyundai ImageQuest Q15 15.1" Flat Panel...
80g ipod video. screen has ipod logo and screen
hold the select and menu buttons until the apple logo shows up, then quickly switch to holding the select and play buttons, this should put it into "disk mode." plug into itunes and click restore.
Nov 16, 2009 | Apple iPod MA446LL/A MP3 Player
Iphone fell, now has alternating frozen screens
do as i say i think it will work ........... Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Apr 09, 2009 | Apple iPhone Smartphone
17" Sony Monitor Goes Black and No Light Shows On The Switch
Sounds like your backlight bulbs are wearing out.It is a common problem with Sony LCDs. Difficult to replace then.
Monitor Mike
Jan 03, 2009 | Sony SDM-HS73P 17" LCD Monitor
Monitor shows screen then goes black
It is the Monitor Cable connected to the CPU cabinet is faulty. Please check out the cable and its pin firmly.
Try to find the fault, may be the cable broken or tear up.
Let me know if further diagnose required.
Have a nice day.
Ellin
Oct 14, 2008 | Hyundai ImageQuest Q15 15.1" Flat Panel...
N 73 screen
remove the memory card and try it work's properly. after u just insert the memory card i likely to be working.. better u need to format the memory card..
Sep 06, 2008 | Nokia 6230i Cellular Phone
White screen
This is the problem with corrupted phone software you need to reinstall the phone software get it done by the company if it still under warranty or if its out of warranty get it done in local mobile service center..
Good luck..
Aug 19, 2008 | Nokia 7373 Cellular Phone
How di I get my K850i to show the time in screen saver mode
Press the volume button on the side of the phone to display a screen similar to previous Sony Ericsson Cybershot phones during standby mode. It will display the time and a message icon. This is probably an energy saving feature when the screen goes black in standby mode, but you must press the volume button to get to that screen.
Feb 25, 2008 | Cell Phones
Hannspree HW191D LCD Monitor Logo
282 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
