FixYa.com
Tags:
Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-in-one (by 23 users)
By man1 - usenet poster
Having serious issues with Lexmark X4270 Printer, Fax, Copier and Scanner.
1st was the spooler issue. Solved and printer worked for 1 week. Now there
seems to be a problem with communication. XP will not communicate with
printer. Uninstalled - reinstalled did not work. Manually cleaned out
registry - reinstalled did not work. Spooler file is clean. Any ideas?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
22 Other Users Have The Same Problem
Comment by Guest, posted on Jun 29, 2008
i cant reinstall the printer its saying there is no printer attached to the computer
Comment by boob2, posted on Jun 11, 2008
needs to be installed dont have the disc
Comment by Guest, posted on Jun 09, 2008
wont print nor copy nor fax
Comment by Guest, posted on Jun 08, 2008
can i install x4270 on my vista computer?
Comment by Guest, posted on Jun 07, 2008
I have the same problem as man1 has. Maybe I need a new install CD?
Best Solution
posted on Aug 10, 2005
FixYa! (100)
Rachel007
Rachel007 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Yes. I found the bios was updated by Dell from A02 to A03. A swift drive to
the local Wal-Mart for a 1.44 mb disk and an even quicker download and
install fixed the bios chipset for the usb driver. Printer is working great.
Any one using a Dell should regularly look for bios updates.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Sep 26, 2007
FixYa! (100)
Guest
Guest
Rating: 0%, 0 votes
did you try their online tech support? just go under the support to type in your X4270 and look under support tools and then e-mail support.
Solution #3
posted on May 09, 2008
FixYa! (100)
Guest
Guest
Rating: 0%, 0 votes
hi
i have one printer 4270. i lost cd. i need softwere cd
thank
Solution #4
Helpful (85)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
Have you looked for updated drivers???
"Will B." <Will B @discussions.microsoft.com> wrote in message
Solution #5
posted on Jun 17, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I had the same problem...tried everything noted....fixed by UNPLUGGING PRINTER for at least 10 seconds,
Unplugging is NOT the same as turning off. My guess is that the circuit boards were zapped by a power surge...Lightining during a storm? and unplugging powers down the power supply boards, which turning off does not.
Now it works fine. Hope this helps.
Solution #6
posted on Jun 14, 2008
Not Rated (0)
taher rangwa
Rating: 0%, 0 votes
i wont softwer of x4270 with saport of win xp srvice pak-2
Solution #7
Not Rated (0)
weppler
Rating: 0%, 0 votes
i can not get printer to work on vista computer! will it work ?
Can you Help with these Printers problems?
No instruction book for my...
I bought a Lexmark X4270 Fax,... Answer This...
lost cd that came with the...
i gat a new computer and still... Answer This...
says comp. not comunicating...
when I try to print a window... Answer This...
error 1203
can you please help me with... Answer This...
ERROR #1203
The Lexmark X4270 is... Answer This...
22 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 02, 2008
y can't install my fax
Comment by Gladys fax, posted on May 05, 2008
Cant send fax. Keep getting remote fax error notice.
Comment by Deanna2, posted on Apr 18, 2008
I can't get it to program to my computer
Comment by mew7561, posted on Apr 15, 2008
4270 printer will not install
Comment by twilson2008, posted on Apr 05, 2008
My Lexmark X3350 got uninstallled and I can't find the disk to reinstall it
Comment by Guest, posted on Mar 19, 2008
NOT ON MYDRIVE
Comment by eggman12, posted on Mar 17, 2008
windows xp is not in the drop dowm menu for compatability.Printer does notprint micosoft works.
Comment by Guest, posted on Dec 10, 2007
an error message comes up,cannot connect to computer
Comment by Guest, posted on Nov 26, 2007
printer will not install to computer(e-machine) spooler printer not working
when i try to install my printer it bring up an error that the spooler want start
Comment by carrington, posted on Nov 19, 2007
I've had my X4270 for a few years, and I just bought a new laptop HP Windows Vista Home Preminum. I knew I needed a updated software for windows vista so I downloaded it to my computer in order for the x4270 to work. The printer is the only thing that works. I can't fax or scann anything from my x4270. Do you have a solution? I check all connection, uninstalled and reinstalled.
Comment by X4270, posted on Nov 09, 2007
I have a problem with Lexmark X4270. It was printing and scaning before. And now, that I changed my computer and tried to reinstall Lexmark X4270, it does not work. I tried to troubleshoot, it did not work. I tried printing a sample, it did not work Please provide solution.
Comment by Guest, posted on Nov 06, 2007
my spooler is the problem
technical support was`nt very helpful
tried to down load a driver
used the cd provided nil result
Comment by GODZILLAIN, posted on Nov 05, 2007
MY LEXMARK X4270 AS TROUBLE PRINTING IN WINXP
THE TELEPHONE FEATURE WORKS, BUT ALL THE REMAINING DO NOT WORK. CAN YOU HELP?
Comment by courierleo, posted on Nov 03, 2007
cannot instaall driver, and said spooler not working uusing window vista premium
Comment by Guest, posted on Nov 02, 2007
I cannot connect the all-in-one to the computer. I connected the usb cable correctly, but when I load the install disk, an error message is returned that the printer cannot be found. If anyone has similar problem let me know. I have Windows XP.
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
