Question about Car Audio & Video
Once i turn my ignition off my stereo reset itself. the clock goes back to 12:00 . I have an infinity sound system in my dodge intrepid.
    Sergeant:
  • 436 Answers
You have got the memory wire and ignition wire the wrong way round, this needs to be changed. red and yellow wires.
Posted on Dec 10, 2009
Tip
How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe
Hi, on most vehicles, the airbag light should come on for at 6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag light system. When the light is on (or the tone is sounding), the airbag will NOT deploy, even in an accident. <br /> The flashing light on your car is telling there is a problem. <br /> <br /> <b>How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe </b> <br /> Ignition Key Method: <br /> <ul> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 2 seconds.</li> <li>START Car (the light may be blinking slower than before).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 3 seconds.</li> <li>START Car.</li></ul> <br /> <b>This is a little easier</b> To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
on Dec 07, 2010 | Infiniti G35 Cars & Trucks
Dodge infinity
The Infinity system includes a CD/cassette receiver or a CD receiver in the dash, and a complement of 7 speakers: 3-1/2" speakers in the dash (left, right), a 2-1/2" center dash speaker, two 6"x9" woofers in the front doors, and two 5-1/4" speakers in the rear doors. You'll have to remove a section of the dash to install a new stereo, as you do with the non-Infinity system. You'll need a special adapter to connect a new car stereo to the Infinity factory amp http://www.crutchfield.com/p_120CHTO02/Axxess-CHTO-02-Factory-Integration-Adapter.html?tp=3486
Dec 25, 2013 | Cars & Trucks
Why do my settings reset in aftermarket stereo of my 92 mercury cougar
As well as the normal 12 volt line form the ignition switch, there is a 'permanently on' 12 volt lead, which keeps the clock and memories going even when the ignition is turned off. It sounds like the installer has missed connecting this one.
Aug 28, 2012 | Pioneer Audio Players & Recorders
How do i hook up an after market stereo in a 1998 dodge durango slt with an infinity sound system w/amp
get an adaptor kit for the stereo wiring. it will plug directly into the factory harness and vertually eliminate cross-wiring.
Jun 19, 2012 | 2009 Dodge Durango SLT
How do I reset the security on a 2001 Dodge Intrepid?
I can't see your system from here so lets try it this way. Undo the negative battery cable and take it off the battery. Then turn your ignition key to on position. Then turn your headlights on, the radio, and the heater and let it sit there for 30 minutes. This will drain any reserve or stored up power. The turn off all the features not forgetting to turn off the lights and key. Re-attach the battery cable and tighten it down so you can not turn it by hand. then see if everything is reset. It should put it all back to factory defaults. Keep me informed, Raz
Apr 18, 2010 | 2001 Dodge Intrepid
2004 Dodge Ram 1500, Infinity sound system. CD/AM/FM not working.
You most likely need a new radio. They go bad all the time in the Chrysler/Dodge/Jeep. Don't know how many of them I have replaced.
Jun 18, 2009 | 2004 Dodge Ram 1500
1994 dodge interpid wont start
it could be the coil or it may gust be a badground
Mar 23, 2009 | 1994 Dodge Intrepid
Do my 2004 dodge intrepid have a kill switch?
Your dodge has an antitheft system that shuts down the ignition and fuel system when the lock was tampered with. This is why they did not take the car your anti theft system did exactly what it was designed to do. You will need to get it to the dealer to get the system reset.
Mike
Jan 07, 2009 | 2004 Dodge Intrepid
Clock not available
I took the truck back for warranty work and this was the dealer's explanation: This is a known, but rare, glitch in the radio. It is not widespread enough for Dodge to issue a bulletin, but there is a write-up in the computer system that Dodge technicians access that covers this. The "repair" is to disconnect the battery for 5 minutes and/or remove the IOD (Ignition Off Draw fuse(s)). The radio then "resets" itself. If the problem persists, they have to replace a component of the radio system.
Jan 06, 2009 | 2008 Dodge Durango
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
