Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
SVE471008 Oven temperature is not correct. Never has been right. Some times it gives an F1 error and beeps, cuts off oven and time when that happens. It's sometimes 10 degrees too low or sometimes 40 or 50 degrees too low. Thanks!
Problem fixed!!! Lowes is giving us a new stove!!!
Posted on Oct 10, 2009
SOURCE: Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Posted on Nov 04, 2009
  • 969 Answers
SOURCE: jenn air jds8850aas f1-1 code and beeps when oven
Posted on Nov 12, 2009
  • 6784 Answers
SOURCE: F1 fault code? Jenn-Air SVE47100
HI. This is concerning the relay board that is installed in your unit. I would recommend to inspect the entire wiring harness that is linking the relay board to the elements, and other power component's. If the harness is ok, and connected tightly, and correctly, this will confirm that the relay board has failed. It must be replaced in the case. Be sure to inspect all wiring harness connections for corrosion before you replace the board. This could be as simple as a failed connection.
PRB Part Number is #71002144
Posted on Nov 14, 2009
SOURCE: My oven heating element doesn't get red and the
I removed the heating element and checked it with an ohmeter, which showed the element had shorted out. I've purchased another element on line.
Posted on Nov 22, 2009
When turning oven on there is a beeping sound and error code F1
Most of the answers are correct, the EOC (Electronic Oven Control) is either damaged or shorted. I've also seen the F1 code come up on the version 2 and 3 units when the temperature probe was shorted. But most likely your EOC is damaged and needs to be replaced. Since you didn't give us a model number we can't give you any more info. Good luck
Mar 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19:
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
Oven is giving a F1 code and is not working . It beeps even when it is not given a program.
The error meaning depends on the oven brand.
On Amana and other brands F1 is a faulty control pad or faulty electronic control.
That may be your case , since the electronic control looks being jammed.
Try tripping the circuit breaker for two minutes (or disconnect power cord). If that does not help, then call the manufacturer at the number listed on the owners manual.
Note: on other brands F1 indicates incorrect temperature , and is associated with a faulty temperature sensor. This normally does not cause the electronic control beeping and not responding.
Mar 02, 2010 | Ovens
Cleaning oven got a warning beep and an F1 indicator in light panel
F1 error code normally means the oven temperature has exceeded the safe limit for the oven and the beep is to warn you to switch off until it has cooled down.
Normally this is caused by failure of the oven temperature control sensor which then fails to cut off the power to the heating element as it should.
Sometimes it is just a 'glitch' wich can be solved by turning off the power to the oven for a few minutes and then turning back on but if the problem persists you will need to replace the sensor.
Jan 12, 2010 | Jenn-Air Ovens
Flashing F2 warning
Range/Stove/Oven Fault Codes Failure
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
F3 & F1 Errors & oven shuts off
Concerning the F3(Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Concerning the F1(Stuck touch pad)
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Jun 02, 2009 | GE Ovens
What does the error code F1 indicate, on a Wolf Oven?
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 24, 2009 | Ovens
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
F1 Error Code
try fix at
this is a common error and easily fixed
Dec 19, 2007 | GE Profile JTP18 Electric Single Oven
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
67 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
