Advent 5421 wont power up,iv bought new power adaptor and its the same.,the orange battry light stays illuminated and thats it,iv tried it with the battry out and power adaptor in but nothing,its only 2 weeks out of guarantee so not old
  • audrey_tait Dec 10, 2009
    its a 19volt adaptor,when id went to shop and said mine broke they binned it and sold me new universal one and set it to the right voltage,its just the same now with orange light on
When i turn my laptop on the advent logo comes on and the bar at the bottom goes up 3 quaters but then stops and thats it. the screen freezers.
Posted on Jan 03, 2010
  • 94 Answers
 please cheek the power specifications in the new power adapter if it complies, if it does contact me for more tips. cheers
Posted on Dec 10, 2009
What cause battry to die over night?
If test light is a 12 volt light tester AND ILLUMINATES BRIGHT it shows that a component is actively trying to complete a circuit and yes drawing power causing a drain on your battery, now if test light illuminates low, possibility could just be ecm memory or antitheft system active . either way this test should only be done with a 12 volt test light as if you use a 5 volt (computer friendly) tester , false light will have you chasing a ghost. trust me. that trick helps by checking for parasitic draws a 12 volt tester does not illuminate when keep alive memory voltages are present . those voltages are not enough to drain over night. good luck
Nov 28, 2017 | GMC Cars & Trucks
Why are my battry light staying on?
does it stay on when you have driven the car for a few minutes? if you did not drive it , try that
Nov 03, 2016 | Toyota Cars & Trucks
How do I fit a new cooling fan to a Uniwill U50SI1?
http://repair4laptop.org/disassembly_advent.html Here are some pictures that might help. I do not know if they are close enough to your model or not.
Aug 04, 2014 | Advent Computers & Internet
Advent 7109b battery wont charge
Yes! it is very possible, specs are different in none original power adapters, because it sounds like the charging circuits are working. I recommend getting the original adapter for your model.
Apr 19, 2012 | Advent Computers & Internet
Ac adaptor blinking orange. Xbox360 won't power up.
An orange light is illuminated on the power supply for one of the following reasons:
  • The console is turned off.
  • The power supply is disconnected from the console.
  • The power supply cord is not fully inserted into the power socket of the console.
  • The power supply is faulty.
  • The console is faulty. (The console might be faulty if it does not turn on when the power supply light is orange.)
Step 1: Try to connect and then disconnect the power supply
loadTOCNode(2, 'whattotry'); Follow these steps to connect and then disconnect the power supply:
  1. Turn off the Xbox 360 console.
  2. Disconnect the cord that connects the power supply to the console.
  3. Reconnect all the cords, and then try to turn on the console.
if after this also your console does not power up then you need to check if you are seeing any flashing red lights on the power button of Xbox 360, if you see the red flashing lights then you would have to get your power adaptor replaced by calling up MS Customer Support.
If you do not see flashing red lights on the console power button in that case the console itself would have to be send for repairs
Please do rate my solution, Wish you Happy Holidays and Happy Gaming
Regards
KreativeGeek
Dec 29, 2009 | Microsoft Xbox 360 Console
200MBPS Advent powerline adaptors dropping connection
It is normally reccommended that the adaptor goes straight into the socket so check the faulty one to see if it does rather than being plugged into a power strip.
Hope this helps
Mark
Aug 25, 2009 | Wavetek Acterna LT 8155T (LT8155T) Network...
Wont turn on
you have one of 3 things wrong here.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Mike @ compurepair.
Dec 16, 2008 | Toshiba Satellite A100-S8111TD Notebook
Compaq armada m700 wont power up all the way
Sounds like you may have a problem with the internal power supply box? I am not sure but that may be at least something for you to have checked out. If the fan is not spinning this is usually a sign this may be what the problem is. GOOD LUCK!
May 13, 2008 | Compaq Armada M700 Notebook
PSP Won't Come On Without The AC Adaptor
try geting a new battry you may have fused it wen you dropped it
Oct 14, 2007 | Sony PlayStation Portable (PSP) Console
Camera wont turn on even with new batteries
In order to narrow down the issue, I suggest you the following steps. 1) First of all we have to power drain the Camera. Take out the battries and unplug adaptor, now hold the power on putton ( Click Button) for a minute this will clear the static power on Camera. If this doesn't fix the issue, Than.... 2) As cam is working fine with Ac adaport and batterys are not working you have to check the cam with the new battries. If you store battries for a long time with out using them, they may result in battery drain. If this doesn't work. 3) Then it need a Physical check, where we can track if Power suply from battries are reaching till its destination or not. This is the way to narrow down the issue. Thanks you.
Apr 08, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
Computers & Internet Logo
501 people viewed this question
David Payne
David Payne
