Here are the steps to program your YK524-01 remote to your Toshiba TV using a code:
Turn on your Toshiba TV.
Press and hold the "TV" button on your YK524-01 remote until the LED light blinks twice.
Enter one of the following 3-digit codes for Toshiba TVs: 115, 125, 136, 156, 159, 160, 170, 179, 185, 195, 204, 216, 218, 227, 228, 229, 231, 233, 235, 236, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255.
Press the "Power" button on your YK524-01 remote. If your Toshiba TV turns off, the code has been successfully programmed. If your Toshiba TV does not turn off, repeat steps 2 to 4 with a different code from the list.
If none of the codes work, you can try the automatic code search method:
Press and release the "Power" button on your YK524-01 remote.
Press the "CH+" button repeatedly until your Toshiba TV turns off.
Press and release the "TV" button on your YK524-01 remote to save the code.
The URC-01 is a universal remote control that can be programmed to work with various devices, including your Sankey CLCD-1936 TV. Here are the steps to set up the remote to control your TV:
Turn on your TV and point the URC-01 remote control towards it.
Press and hold the "TV" button on the URC-01 remote until the red LED light on the remote stays on.
Enter the TV code for your Sankey TV. The code for Sankey TVs may vary depending on the model, so consult the manual or the website of the remote manufacturer to find the code for your specific model.
Once you have entered the code, the LED light on the remote should turn off.
Press the "Power" button on the URC-01 remote to test whether the TV turns off. If it does, the setup is complete.
If the code you entered does not work, you can try entering another code by repeating the above steps. Alternatively, you can perform an automatic code search by following these steps:
Press and hold the "Setup" button until the red LED light blinks twice.
Press the "Power" button on the URC-01 remote.
Press the "Channel Up" button on the URC-01 remote repeatedly until the TV turns off.
Once the TV turns off, press the "Setup" button to save the code.
Test the remote by pressing the "Power" button to turn on the TV.
If you are still having trouble setting up the remote, consult the user manual or contact the manufacturer for assistance.
there might be a wire inside the plug shorting out, it could of happened over time when unplugging, i mean pulling on the wire to unplug it instead of pulling on the plug.
if hunter remote does not turn on fan . then problem with remote or reciever. remote part # 85095-01--just type in on browser, hunterfan.com and click on support find phone number. they will help with problem. have a good day !!
hi 1st check if light working 2u can not run all lights at same time; ok u need a rely4 pin or 5pin rely 85 86 pins to energize the rely pins 30 87 is used to energize the lights 87a is not used center pin; 3need tagl switch that have light ;find right wire for parking lights hookup 85to that wire 86 go to Negev 87 go to a15 amp fuse that gets power from B+ .30 go to plw lit now u can run low beam+plw or H beam+plw now u can run safly evriting
Press menu on the remote
Ignore the menu, press the numbers 2007
Press OK on Nagravision
Choose your provider
Enter both keys 00 and 01, saving each key individually
Finished
It's important to have the latest update on your box as it will auto-update any key changes.
