Question about Whirlpool Dryers
Blowing air no heat open up dryer at the bottom on the heating element there is a burnt looks like a small relay that be the problem for no heat
  • 291 Answers
This problem is usually a blown thermofuse. Whirlpool Dryers usually have two thermostats or thermofuses on the heating element case. Unplug Dryer, remove one wire from the thermostat, and with an electrical tester you need to test for continuity or resistance between the two terminals on each thermostat. If you have no continuity on either thermostat, order new ones, they usually will only sell as a set. If their is any burned wiring you have to cut out the burned section and put on new wiring terminals. 99% of the time this is caused by a venting restriction, so make sure your vent is clean and not smashed or restricted, otherwise this problem will reoccurr. If your thermostats have continuity, test for continuity across your heating element terminals. If this doesn't take care of it let me know and I will walk you through other tests
Posted on Dec 10, 2009
Dyer will not heat
Sounds like an open heating element issue. If you have two sensors for internal temps, the chances of both going bad at same time are remote.
Locate the element wiring and disconnect from circuit and do a simple continuity test. Chances are that it is burnt out or open.
Jan 28, 2014 | LG DLE7177 Dryer
Wd51 drying not heating
there are a few things that can cause the dryer to not heat there is a one time thermal fuse that can blow causing the heating element to not function . one cause of this thermal fuse to blow (in this case heat) would be the lint in the dryer vent tube it clogs the tube then the heat builds up by the heating element and blows the resistor this is very common . One other problem that can occur is the heating element could get burnt out and short out .after some years of use the wire come out of its normal shape and move around and eventually touch the side of the metal housing causing the element to open or break. you can check out this site www.repairclinic.com and put in your model number and find the thermal fuse kit should cost around 22$ the heating element can be from 60 -180$ depending on what type of dryer you have
Nov 24, 2012 | Dryers
Not heating
There are a few things that can cause the dryer to not heat there is a one time thermal fuse that can blow causing the heating element to not function . one cause of this thermal fuse to blow (in this case heat) would be the lint in the dryer vent tube it clogs the tube then the heat builds up by the heating element and blows the resistor this is very common . One other problem that can occur is the heating element could get burnt out and short out .after some years of use the wire come out of its normal shape and move around and eventually touch the side of the metal housing causing the element to open or break. you can check out this site www.repairclinic.com and put in your model number and find the thermal fuse kit should cost around 22$ the heating element can be from 60 -180$ depending on what type of dryer you have
Nov 24, 2012 | Whirlpool Dryers
They dryer wont get hot. the drum still operates but will not heat up to dry. need information on part cost and how to fix.
You first need to know, is it electric or gas. If it is electric, you more than likely have an electric element burnt out. Most dryers have one element and can be accessed sometimes through a small door in the front of the dryer (depending how old). An "element" is a long coil looking wire that looks like a real long spring. It gets hot and air passes over the element into the dryer. If the element burns out, the dryer will come on, but no heat. You can visible look at the element and sometimes you can tell if its burnt in two. Be sure to unplug the dryer before inspecting.
Apr 08, 2011 | Dryers
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
Dryer blows air, but no heat - the dryer powers on, the drums turns and the fan blows air, but the air isn't hot.
There is one of two possibilities:
1.-The heating elements dont come on due to a wire burnt off or the element itself has burnt out.
2.- There is a small electronic device in the element circuit called a thermal overload switch, which has and often does malfunction, stopping the power to the elements.
Best wishes,
Graemevm
Dec 17, 2009 | Office Equipment & Supplies
No heat it blow air and rotates
your dryer may need a new heating element.
unplug and remove the back cover.
your looking for a grey rectangular box with red
wires coming out the bottom..
undo those wires noting location, (take picture )and the safety limiter wires also.
remove the box and put it on a workbench.
you need to remove the element out of that box now. there are a couple more screws that release the inner element.
study the element and look for the break in the element wire, you should be able to spot it.
you can get a replacement element at the sears appliance store outlet in your area for around 25.00
jm
Nov 28, 2009 | Whirlpool Dryers
I have a DV306LEW/XAA dryer that is about 4 years old. It now has no heat. It is tumbling ok and the blower is working fine, it just blows cold air. I opened the small lint hose cover a vacuumed everything...
There is a thermal shutoff on the heating assemly that will turn off the dryer heat. Also, we just experienced a fire in ours due to lint build up in the body of the dryer even though we vacuumed out the lint trap on a regular basis. To look in this area, you have to take the top off the dryer and then the front. You can look by pulling out the dryer outlet connection and a flashlight. Make sure to put it back in correctly though to avoid a fire.
Nov 22, 2009 | Samsung DV306LEW Electric Dryer
Dryer turns and air blows, but no heat. GGQ8811KQ0
Make sure that your dryer air vent is not being blocked by lent, and if it is not it is your element or thermocouple?
Nov 07, 2009 | Kitchen Ranges
No heat
If this is a GAS dryer make sure that the igniter or pilot light has not gone out. If this is an electric dryer, check the vent to make sure it has not clogged up and prevents the air from circulating in the dryer.
Otherwise if it is an electric dryer, make sure the heating element has not blown a fuse or burnt out.
Feb 19, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
80 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
