Question about IFS D7130WDMA-R3 Repeater
How many rack slots does the ifs D7130WDMB-R3 occupy? and how manny does the D7120WDMB-R3 need?
    Scholar:
  • 64 Answers
Typically that R3 at the end of a rackmount product tell you how many "rack units" or (RU) it will take up. 1 RU = 1.75 inches. Only prob is doesn't seem to match the unit specs. Data sheet say 2 "rack slots"
Take a look:
http://www.signalcontrol.com/products/ifs/IFS_D7100_Series.pdf
Both in the same series, so appears to be same size.
Hope that helps.
Posted on Dec 10, 2009
K7s8x asrock won't enter post after inserting ram upgrade
need more info.What memory did you use?
That MB requires either DDR PC2700 or DDR PC3200 Unbuffered,NON-ECC memory.
Max of 1gib per slot.
Jun 25, 2016 | Asrock K7S8X-R3 Motherboard
How to install
Shut down the PC. Open the case: On the back there is a button that releases a panel at the rear of the top. When that is raised, the side comes off. Once inside, there are some connector slots on the motherboard. If you have dual video cards, you may not have any free slots! Remove the cover on the case for the slot you will use. Plug in the card. If there was a screw holding the cover for the slot, use it to lock in the card.
If you don't have any open slots, you can use a USB wireless adapter, and return the card.
Nov 05, 2013 | TP-LINK TL-WN350G, 54Mbps Wireless PCI...
How do I get to the memory slots in an acer aspire 7750z-4623? My computer has 4 Gig, does it come with 4 1 gig chips or 2 2gig chips? Do I have an free slots? Thanks-Bill
Hi.
First of all remove the AC power and take out the battery. Turn the laptop upside down and you should see a couple of panels with screws. Remove the screws and take off the panels. Under one of the panels you will the system memory which looks like this >>>>
On that model laptop there are 2 slots, both should be occupied with DDR3 modules each at 2GB. Your model however may have a slot free with one slot occupied with 1 4GB module, that you will have to check yourself by removing the panels.
The laptop supports 8GB maximum, that is 2x4GB modules.
Regards.
Aug 02, 2011 | Computers & Internet
I WANT TO BUY A MOTHER BOARD WITH FOUR SLOTS AND EACH SLOT CAPABLE OF TWO GIGABYTES OF MEMORY OR MORE
You could use a BIOStar N6853, which supports up to 8GB of memory. That is, if you intend to use an AMD motherboard.
Jul 15, 2011 | Asrock K7S8X-R3 Motherboard
Gateway Foxconn C51GU01 (105552) Problem: blue
Possible a memory socket is bad. Make sure you are using the correct type of memory including parity and compatible speeds. It is recommended to use like memory sticks in each slot. Some PCs even require the sticks to be equal memory capacity. User's guide should tell you what the compatible capacities and speeds should be. If you don't have the manual, you can get by looking up your PC model number on Gateway.com.
Bret
1-2-1ComputerServices
Oct 04, 2009 | Gateway GM5084 PC Desktop
How do I use the dryer rack in the Frigidaire Infinity gas dryer. I can insert it but what do I do to keep the drum from rotating and tossing the rack aroung?
Do you have a lint filter slot inside of your dryer or on the top? Our rack in ours mounts into the lint filter slot and the drum turns around it and does not turn the rack. If you have a lift filter that is on top of the unit the rack may mount into the back panel allowing the drum to turn around it.
Mar 03, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Replacing Partner 308 w/ 509&400EC
You don't need the 400 module for the voicemail. Therefore, you also don't need the 2 slot carrier either.
Feb 27, 2009 | Avaya PARTNER RELEASE 7 RAC-REM ACCESS...
I want to know if my hp computer model a6418f has a pci slot anywhere.
According to the HP specs, it does, but is states occupied (1 PCI (occupied), 1 PCI Express x1 (available), 1 PCI Express x16 (available)
You would have to open the case to see if that is true.
Jul 27, 2008 | HP Computers & Internet
Spring w/2 tiny rollers loose
On my i455 all the rear slots are occupied. The front only has 2,5,7, 8 occupied. It works fine that way. I think the rear is more critical than the front to proper paper feeding. Good luck
Jan 16, 2007 | Canon i 450 InkJet Printer
IFS D7130WDMA-R3  Repeater Logo
102 people viewed this question
Top IFS Computers & Internet Experts
David Payne
David Payne
Are you an IFS Computer and Internet Expert? Answer questions, earn points and help others
