Question about Sewing Machines
One side of my queen-size electric blanket no longer heats. I thought to reverse it because I only need the extra warmth on my side of the bed. But, the label indicates this should never be done. The blanket is about three years old - used only about two months out of the year and is carefully stored in a cool dry closet the rest of the time. When in use, it is placed between the top sheet and a light over blanket. Why does it make such a difference if I reverse it? Does this mean I have to consign it to the recycle bin? What a shame. It's in new condition but it's far too costly to ship it for repair. I live in Calgary,AB. Is there a repair location here in the city? Thank-you, Irene.
    President:
  • 1,615 Answers
One thing noone will do is recommend what the manufacturer recommends against. If a fire were to happen, well need i say more.
As far as repairing this its cheaper to replace it. You could put the connector to the side so either your lower or upper parts stay warm.
Posted on Dec 10, 2009
I want to expand my ripple baby blanket pattern to make one for a two year old,I have 157 stitches now,how many extra would I have to add,it is being crocheted
Depends on pn you gauge, how many stitches to the inch, then work out how many more you need to add to get more inches.
That is. measure your work now and see how many crochet stitches you are doing to the inch and take it from there. :)
Jan 08, 2018 | Sewing Machines
How can I stop my hexagon crochet blanket waving
It is creating waves because there is too much yarn causing the project to ripple. Be sure that you are counting the stitches correctly. Frequently, extra stitches will cause rippling. You need to:
1) mark the beginning of each round with a safety pin so you can accurately count stitches
or in extreme cases:
2) decrease the size of the needle
or
3) use a lighter weight yarn.
Best thing is to crochet a swatch and compare the measurement to what is recommended in your pattern, ie it will say 10 stitches=1 inch, etc. When you get your swatch to match the guideline, then your project will probably lay flat.
The following may also be helpful:
https://www.thriftyfun.com/tf41221053.tip.html
Oct 26, 2017 | Sewing Machines
Will not sew continuestly when im embrodering when i press the reverse button
It is completely normal for a Bernina 180 and other Bernina models to stitch just a few stitches and stop after first pushing the reversing button. The reason for this is so you can cut off the extra piece of top thread so it does not get caught up in the embroidery design. After you cut off that extra piece of thread, press the reversing button (hold it in till the machine starts) then it will continue with the design. Assuming you do not have a problem (a message would come up on the screen) or you are out of bobbin thread, the machine will continue to embroider till either the design is finished or it stops because you need to change the upper thread to the next color. Each time you start to embroider it will stitch about 3 or so stitched and stop. Cut off the extra thread and press the reversing button again to continue.
If this is not the problem you are having then you need to describe your problem better, in more detail.
This should help! Bill
May 26, 2015 | Bernina Artista 180
The reverse button does not work
The button is a relay switch and is an electronic component
Quite easy to replace, but you need to get parts from Janome Authorised Dealer
Feb 28, 2015 | Janome D'cor Excel Pro 5124 Mechanical...
Bernina 1030: the stitch size/reverse lever no longer works.
Not sure what you mean by no tension from the top. If you mean that you cannot feel the spring action when you push the lever up into reverse, you need to take the machine in for repair.
Feb 20, 2015 | Bernina Sewing Machines
Will not sew. When attempting to, it moves in reverse without setting it in reverse.
If you have had this machine for long time the problem is most likely the reverse mechanism is stuck. On a lot of kenmore machines the reverse is a spring loaded lob that slides side to side on the lower shaft. Over time the lube that was used dries out and turns pasty. The spring can no longer push the lob and the machine stops reversing properly. It needs to be cleaned and relubed. Best bet is a sewing machine shop with a good repair person. If it is a new machine it could be something else.
Sep 16, 2013 | Kenmore 16622 Mechanical Sewing Machine
Zigzag stitch not catching
try these suggestions and see if they help
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Oct 19, 2012 | Brother CS6000i Computerized Sewing...
I have a Pfaff Hobbymatic 927, while I am sewing, when the needle goes down into material, sticks abit and gathers the material a little and then on bottom side of material threads of material show a...
Try changing to a new needle preferably size 80 universal. If you hear a little popping sound when you sew, that's telling you that the needle is bad and is no longer sharp. The needle either has no sharp point or has a bur on it which is pushing down into the material making a hole and on the way back out it's pulling the fabric with it. Let me know if this works for you. Good luck.
Sep 10, 2010 | PfaFF Sewing Machines
Due to illness from a collision with a drunk driver in '90, I had my leg amputated mid April and moved June 30th. Needless to say, I didn't pack each and every piece of equipment. My carefully handled...
its difficult with serial number as model and manufacturer is required. you will have to get the details by local electric appliance store dealing with this products. as they will give you details of the manufacturer by checking the unit make and model. thanks.this will help.keep updated.
Nov 30, 2009 | Sewing Machines
Designer 1 reverse won't select, no light at all
The designer 1 has a weakness of the reverse pad (rubber button set) on left side of the machine wearing out and not working. You can try pushing from different angle, or pushing hard, but it most likely needs to be replaced. If you did buttonholes with the buttonhole sesor foot (foot with a wheel and a cord that plugs in), it would automatically size the buttonhole and you wouldn't need to reverse and you can use "FIX" to tie a knot instead of reverse
Dec 30, 2008 | Husqvarna Viking 1
Sewing Machines Logo
16 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
