Question about Kenmore 24 in. 16032 Built-in Dishwasher
My kenmore ultra dishwasher model 665.15772990 just quit mid cycle. now has no power.
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
SOURCE: Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Posted on Feb 08, 2008
  • 4 Answers
SOURCE: Kenmore Dishwasher model # 665
replace control board
Posted on Feb 16, 2008
SOURCE: Kenmore Ultra Wash Dishwasher - 665 - 13783
dcvxzcxzcxzczxc
Posted on Feb 26, 2008
SOURCE: Won't Power on!! Help its starting to smell bad
will not start
Posted on Aug 09, 2008
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
Kenmore Ultra Wash Dishwasher door won't open
It seems most likely door latch stock and you going to need buy new door latch as for stock one most likely you hsve to forceit to open and replace it with new one
Dec 09, 2013 | Kenmore Dishwashers
My kenmore elite model # 665.15934000 quit working in mid cycle. Now I do not have any lights on the control panel. The breaker is on. What could be the problem? Doug
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Suddenly stopped working - won't run on any cycle.
First check the electrical supply. I have seen dozens of dishwashers which did not have the hot wire connected tightly enough (inside the connection box behind the lower panel). Sometimes the loose wire caused the breaker to blow. If you have control lights but the dishwasher will not start it could be a bad door latch saftey switch. $10 part, cheap. Hope this helps, Ken
Apr 24, 2009 | Dishwashers
Kenmore ultra quits working pf and e8 light come on
If your pf light comes on that means that your outdoors fuse needs to be replaced. The same thing happened to me and I bought another dishwasher for the same proble to occur. I don't know if it's to late but the only thing wrong is your fuse is blown. Good luck!!!!!
Nov 23, 2008 | Kenmore 13599 / 13594 / 13592 Built-in...
Dishwasher won't start
Drhook65,
Welcome,
I'm Huuum
How old is this dishwasher and the complete model number is?
You said, you have a Kenmore Ultra Wash dishwasher, and you have power running to it, but when you shut the door on it...it still won't start a cycle. Does it have a reset button on it? Any ideas on a solution?
Yes, you may try this to reset the system.
Go to the breaker and switch it off for 5 minutes and the on and try it. It usually resets the systems.
Let me know ho it goes. Huuum
Do not forget to leave a rating.
Sep 24, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Model 16253 - Stops mid cycle
Sounds to me that the heater is not working, if you have just bought it, it must still be under Guarantee so go back to the supplier.
Nov 18, 2007 | Kenmore 16253 Stainless Steel Dishwasher
Kenmore Ultra wash model 665 17779990-Cycle wont finish- Lights blinking
heater element if its not warming up, you didn't say, if it worms up then check the pump
Oct 13, 2007 | Dishwashers
Kenmore 24 in. 16032 Built-in Dishwasher Logo
133 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
