Question about Sharp AR-5316 Advanced Digital Imager Copier
Our copy machine is showing an error code of L4-03. Is this something that a tech needs to come out and fix or is it something we can fix on our end?
  • 622 Answers
Bad fuser motor... call the tech...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 10, 2009
Canon iR6800C printer error code E000002-0001 pls fix this error code on photo coppier machin
Hi. You have to clear that error from service mode
Try to clear that error from service mode
press additional function
2 and 8 together
select copier
select function
select clear
select ERR
select ok. Unplug of the machine for 5 second and then turn it back on
try to make some copies, if problem persists fixing heater is damaged and need to be replaced
Mar 28, 2015 | Canon Office Equipment & Supplies
Showing error code F14 of estudio 225 toshiba machine. what should i do?
Hopefully you've turned it off and back on this illuminates many issues with a product that is more like a computer than a copier. Many of the hot section codes are F then 3 digits if you're not warming up at all it probably will need a Toshiba tech to either reset the code after insuring it won't go into thermal meltdown(you don't want that;trust me) and or replace a safety fuse that saved your machine by blowing. either way does it try to warm up? or it won't let you do anything from minute 1? some times on the newer models the user manual gives at least a clue to the origins of codes thrown, ie. check side door, or close fuser cover panel...... hope it helps but a thrown code is just that something needs a looked at and if it's not real obvious maybe a good service call is what you need. hint: All Toshiba tech's are required to clean/vacuum and make sure the copies are acceptable,it might be be hove of you to get rid of a peskie line going down your copies or even a ugly paper jam when you do double sided copies. good luck! Ex-toshiba tech 23years..~~~~~>SC
Sep 12, 2014 | Toshiba E-Studio 223 Multifunction Copier
The machine does not make copies showing an error E3 which i can not see where i can find it
yep!
e3 means a machine error and it need a service technician to fix it.
furthermore may i ask what e3 code displays on the screen (you might see something like this e3 10 , e3 40 , e3 01 etc)
i can still help you if it is e3 10
Jan 04, 2010 | Panasonic FP-7735 Black and White Copier
IT SHOWS ME THIS ERROR CODE C610 WHEN I SWITCH IT ON.
You have blown your thermal fuse, causing an open circuit.
You have to remove the fuser and remove the thermal fuse. It is very easy to get it, it looks like a round black stump with a shiny bottom with 2 space terminals at each end, the bracket should be white, you cant miss it.
remove the thermistor and throw it hard on the concrete outside, you will not break it, what you are looking for is to make it rattle again, once it rattles again, re-install.. and clear the error code..
To do this you will have to do the following;
Press 'stop/reset' then 'start' then left copy exposure button and hold them all down. This will enter simulation/tech mode.
Enter '163' you do this by pressing the + and - buttons (zoom buttons)
'CLE' should show up (Clear)
then press start.
Reboot the machine and you away again.
Oct 13, 2009 | Kyocera KM-1505 Copier
Code C0500
simulation = UTILIY -----> METER COUNT (on touch screen)->
STOP------> 0-----> 0------> STOP------>0------>1
Sep 07, 2007 | Konica Minolta DiALTA Di200 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
268 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
