Question about HP Compaq nx6125 Notebook
When I press the button it does not start up. Also tried starting up when connected to electric mains but still not starting.
  • HP Master
  • 6,993 Answers
Confirm the status of your power adapter, to ascertain if it is still working or not.
But if the power adapter is till working, then I think your laptop is having a power fault.
You need to take it to a qualified technician to fix it for you.
Take care
Posted on Dec 10, 2009
Testimonial: "Very fast answer to question. Thank you."
2 Suggested Answers
clb199
  • 164 Answers
SOURCE: aspire 3004, does not start up, on pressing start
This is not the answer you want to hear. Unfortunately for you, your daughter has ruined your laptop. You may still be able to salvage your data, assuming your hard drive is still good after you have turned it on and off a few dozen times to no avail.
Nearly everything is located on or solder connected to you motherboard in a laptop.
If you decide to replace the motherboard, all those external connections have to be re-soldered.
1) A liquid (coke) spill on a laptop shorts the motherboard.
2) Any shorts on a motherboard have to be traced using a multimeter and must be done by a qualified technician.
3) For what it is going to cost to repair your Acer laptop, you can buy a new Toshiba laptop at Best Buy or online.
I am sorry, but this is not the answer you were hoping for. The reality is, this is not something that you are going to be able to fix.
Posted on Jan 12, 2010
Hearthland ingnitors clicking
It sounds like an obvious faulty ignitor switch. The button you push to operate the piezo's is permanently on instead of make and break. If you can remove the switch you press, check that it is open circuit while it is not pressed. If here is a reading while it is not being pressed, then it needs replacing or repairing. Disconnect any mains connection before removing any covers. Electricity will kill you. Good luck
Nov 24, 2013 | Heartland 3635B Dual Fuel (Electric and...
I have 2 Epson V500 Scanners, 1 of them I just have on standby. The one I use daily does not turn on. I tried using the cables of the standby unit already. I checked the fuses on the plugs of both...
  1. Check that the power socket switch is on Make sure your scanner's power cord is securely connected to the scanner and a working electrical outlet.
  2. If your scanner is supplied with a power adapter, make sure your scanner's AC adapter is securely connected to the scanner and a working electrical outlet.
  3. Make sure that the power outlet works. (If necessary, test it by plugging in another electrical device and turning it on.)
  4. Check that the power switch is on at the mains socket. If this is on, carefully check the power cable to ensure it is not damaged and remove then reseat it before attempting to turn the scanner on again. If your scanner has a power button, make sure that the button is depressed so it is turned on. Also, make sure that your outlet works and is not controlled by a wall switch or timer.
  5. Power off the scanner at the mains socket. Unplug the power cable from the socket, then remove and reseat the power cable from the scanner's power cable port. Plug the scanner back in at the mains and ensure the socket is switched on.
  6. If your scanner has a power button, does the power button depress when pressed? Press down firmly on the power button, if it is stiff and does not depress then there may be a problem with the button.
  7. Connect the scanner directly to the mains - not via a surge protector or extension lead. If your unit is connected via a surge protector or a power strip/extension lead, connect the unit directly to the mains socket.
  8. Try another suitable power cable. Check that other electronic devices connected to same power socket have power and try another mains socket and another power cable if necessary. Failing this try another suitable and known-working power cable. Depending on your scanner, a standard "kettle lead" or "figure of eight" power cable is used. If there is power to the scanner (indicated by an illuminated Start light), when a different power cable is used, then the fault is with the original power cable.
If the unit does not power on after following the checks above, contact Epson for support. If your scanner uses an AC adapter, then this may need to be replaced. If your scanner is over 12 months old, you can purchase a replacement AC adapter directly from Epson.
Nov 13, 2010 | Epson Perfection V500 Flatbed Scanner
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2010 | Whirlpool GEW9250 Electric Dryer
I have a kenmore Oasis that powers up but wont start
Activate the Console and Indicators Diagnostic Test Mode to check the functionality of the .
Console and Indicators Diagnostic Test Mode Activation
  1. While in standby mode, press the following button sequence within four seconds: SOIL LEVEL>WASH RINSE TEMP>SOIL LEVEL>WASH RINSE TEMP
  2. Press the START button within five seconds of "dt" showing on the display. All indicators should turn on and "88" is displayed.
  3. Press START again. The two-digit display and the status indicators turn off while all other indicators remain lit.
  4. Press START again. The two-digit display and the status indicators turn on while all other indicators remain lit.
  5. Rotate the WASH CYCLE selector back and forth. The indicators will switch on an off.
  6. Press the buttons to check the function. The indicators will switch on or off and a beeping sound will be heard when a button is pressed.
  7. Press STOP or POWER button to exit diagnostic test mode.
  8. If no indicators light up or if no beeping sound is heard when a button is pressed or if some buttons do not light up indicators when pressed, check the user interface board and its connection to the main/control board.
  • Unplug the machine.
  • Remove the three screws on the back of the console.
  • Lift the console off the cabinet.
  • The control board is located on the right side of the console viewed from the front of the machine. Disconnect the middle wiring harness connector on the right side of the control board near the pressure transducer hose.
  • Clean the connector thoroughly to ensure a good connection.
  • Reinstall the console and reconnect power.
  • Run the diagnostic test once again.
  • Replace the user interface board if it fails the test once more.
Refer to the next post if no problem is found on the user interface.
Jan 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Electric start not working
The starter relay may have a loose wire or aone of the battery cables is poorly connected. To find the relay, follow the positive battery cable. Ck the negative cable connection on the frame.The small wire on the r4elay is the wire coming from the start button. There must be current there when you press the button. Good Luck, Ned
Jan 26, 2010 | 2006 Suzuki SV 650 S
My dryer just won't start when I press the start
The electrical breaker may not be turned on. Check the homes main electrical breaker panel and ensure the breaker marked Dryer is in the on position. If this does not work, you may need to call someone in to take a look at the dryer.
Jan 25, 2010 | KitchenAid Dryers
Lap top can not start even button lights
do static discharge
disconnect battery and all peripherals. disconnect from mains. press power button and hold for 30 sec.
Connect to mains and try to turn on again
If it will not start - mainboard needs replacement
thanx
Sep 14, 2009 | Toshiba Satellite M40-S417TD Notebook
Hello!
At the Battery Connections is ther Corrotion? Around at MAJOR Electrical Junktions CHECK FOR Bad Connections its on a MAIN im SURE just Look All Over the Electrical Parts. Bad GROUND ALSO Can do this .be it main POS or Main NEG
Dec 27, 2008 | 1996 Mercedes-Benz C-Class
HP Compaq nx6125 Notebook Logo
166 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
