Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
I have a KitchenAid side by side with water and ice on the freezer door. I copied the serial number from the label high up on the right hand wall (looking in, as you open the door) of the refrigerator. What I copied: KRSL25FRSS00. But that doesn't come up with my refrigerator... What have I done wrong? sherm
  • 520 Answers
Look at your I.D. tag again. There are usually several sets of numbers on this tag. It should be labeled with SIR. or serial - There may also be a separate serial number for the case, or cabinet. That means the refrigerator housing that contains the insulation. The reason for this is because most manufactures outsource the case's. Hope this explaine's the tag a little better. Good luck.
Posted on Dec 10, 2009
My upright frost free freezer is leaking water onto the floor.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number so I can only be general. Your model number is on a label on the upper side wall.
You have one of three problems.
1.) A bad defrost timer.
2.) A bad defrost Heater.
3.) A frozen drain.
4.) A obstruction/leak - Large block of ice in the upper right hand corner of your cool coil.
Mar 12, 2015 | Frigidaire Freezers
Kenmore elite refrigerator
where is the ice,is it on the food and shelves or is it on the back inside wall of the freezer?if it's on the back inside wall of the freezer you have a defrost problem,bad defrost thermostat,heater,timer or board depending on your model number,if it's on the shelves,door and food packages warm air is getting into the freezer somehow either from the door not closing or the door was left open,could have a bad gasket on the door,the ice chute door could be broke and not closing.let me know what you find and the picture shows a side by side but i'll need the model number too,if it's a side by side or freezer on the bottom the model number should be in the fridge section,on the right hand wall up near the ceiling,if the freezer is on top the number should be on the left side wall in the fridge section up near the ceiling.but with this hot wheather we're having if the door was left open this will happen,you can shut down the machine or unplug it,remove the food from the freezer and melt the ice with a hair dryer,don't do this with the machine running because the hot air will cause the same problem,after the ice is melted you can put the food back in and restart it.
Jul 20, 2013 | Refrigerators
Kitchenaid kbfs25ewms2 freezer leaking water
Normally I would agree a water line is the issue however on this particular fridge this is not the case. If you open the freezer door, notice the placement of your hand. Unless it is dead center of the handle this is the cause of the problem and what I believe is a major design flaw. Depending if left or right handed, every time the door is opened the metal tracks that hold the door are being bent. If you remove the bottom freezer basket you will notice the back support bar that is attached to the metal rails is not longer straight.What ends up happening is, certain times when the door is pushed closed it seals completely and other times it does not. The times it does not, there is inch gap between the rubber seal on the door and the fridge itself(left or right side). The freezer warms up and items start to melt. As the cycle of freeze and thaw continues you end up with the entire basin full of ice. Eventually when the door does not shut properly and the ice melts it has nowhere to go expect your floor. This is why sometime you will have a pool of water and sometimes you won't but it always leak from a corner. Learned this first hand and ending up ruining 30sq of hardwood floor
Feb 02, 2012 | KitchenAid KBFS25EW (24.8 cu. ft.) French...
Hot point side by side, back of the freezer inside by the fan keeps building up ice and freezes up the water tube for the ice maker, it will build up enough to hit fan.
if there's ice on the inside back wall of the freezer you have a defrost problem.i need the model number so i can help you.open the fridge door,look up on the right hand side up near the ceiling and you'll see a tag with the number,if it's older look down near the bottom hindge near the kick plate
Feb 02, 2011 | Hotpoint Refrigerators
My friend has a side by side refrigerator. The freezer side works great but the refrigerator side doesn't keep anything very cold. Any suggestions? She doesn't know what brand it is. It has an H on it and...
evaporator is frozen up or fan is not running in freezer to fix you may have to replace heating element or defrost timer or fan motor or defrost terminator
Sep 26, 2010 | Refrigerators
Icemaker water line is frozen...i will remove everything and open the freezer door to let it warm up. When I chill the freezer again do I keep the icemaker arm up until the freezer is cold and then lower...
Dont leave freezer door open it will cause alot of problems. The ice maker will not call for water until the temp in freezer is cold enough. Remove the ice jam. If you remove from back of freezer it helps alot. Pull out of the back wall and remove ice be sure to put it back the way it was. Any further assistance please feel free to contact me.
Jun 16, 2010 | KitchenAid KSBS25FK Side by Side...
I am thinking on buying a used refrigerator. It's a KitchenAid Superba black side by side. Water and ice on door. This is the serial #4176358945 I can't locate it anywhere on the kitchenaid site. How...
Good day,
Thoughts on buying a used refrigerator.
1. Can you see the machine running at normal temperatures. That is, the freezer should be at 0 to 4 degrees and the food compartment at 34 to 39 degrees.(You'll need a thermometer) If not, have it corrected or walk away.
2. Does it it cycle on and off. It should be running 30 to 70 percent of the time. If any more than the high number, either have the problem corrected, or walk away.
3. Does it make ice, dispense it, and does the water delivery system work. Although sometimes easily corrected, repairs can become very pricey.
4. Can you transport it without the machine being layed on it's side? This is critical to the compressor.
5. Parts? If you have the model number as well, with both, call any large appliance parts house. Ask if they can order the bottom crisper drawer for the fresh food side. If yes, then your O.K.
Jun 11, 2010 | KitchenAid Superba Architect KSCS25INSS...
Maytag MFI2266AEU Water and ice dispenser locked, control panel
Door Panel Locked
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue pressing Freezer "-". You will see PE _ _ _ _.
Press Freezer "-" until PE # # # # shows on the panel.
Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0". Press Freezer "-" until PE and numbers blink. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
Look inside refrigerator door and locate the serial sticker. To the right of the serial number is the CODE ####. Plug in your refrigerator.
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-". Using the same method as above, enter the four digit CODE number you found on the serial sticker. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
This unit has a built in safety timer mechanism. If it dispenses water for two minutes, it assumes it is flooding your house and shuts the panel down. If you are filling a pitcher of water, just stop dispensing halfway through to reset the safety timer.
Feb 01, 2010 | Maytag MFI2266AE Side by Side Bottom...
No ice instead water dripping down into freezer making icicles
If you have icicles, where are they forming at? If on the front of the ice bucket, then look at the dispenser shoot door is closing all the way. The way to check that is to look into the shoot while holding a flash light (or bright light) up into the dispenser from the front side of door. You should see no light.
Now if you have ice buildup around the inside of bucket, mainly from the ice maker to the bucket then you either have an ice maker that is leaking water or you have a water valve that is not shutting off all the way. Suspect water valve if you have ice buildup within water inlet tube on top of ice maker. Frozen water within tube is good indication that water valve is leaking.
Look inside refrig side of refrig, usually located on right top side of wall, you will find a tag with model number and serial number. Need both to get you the right part number for ice maker or water valve.
Oct 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
Will not dispense water or ice
Check for broken or frayed wires at the bottom of the freezer door.
There is a wire harness that is routed around the bottom of the freezer door right by the hinge.
After many opening/closings of the freezer door, these wires tend to break or fray and short or open.
Aug 22, 2008 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
