Question about Canon iP100 Portable Printer
My ip100 printer keeps displaying paper jam when there is no paper in the printer
    Novelist:
  • 181 Answers
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Posted on Jan 12, 2010
Printer gives mesasage of jammed paper and will not print
Hi Pedro,
This means the printing paper maybe stuck.
  • Turn the printer off and on.This sometimes clears jam automatically.In case it doesn't:-
  • You need to gently pull the paper out from the rear tray or from the output slot.
  • In case it tears,turn the printer off and open the printhead cover and remove the papers carefully not to touch anything inside.Close the cover.
  • Load printing papers again and press RESUME on the printer to print queued print jobs.
Hope this helps.Thanks!
Please rate this answer.
Oct 20, 2011 | Canon iP100 Portable Printer
My printer keeps showing the message, " paper jam
Hello Tessty,
The Paper Jam message may appear on the display if the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=us&c=ca&lang=en&prod=mfc240c_all&Cat=113
Jun 20, 2011 | Brother Multi-Function Center MFC-240C...
Printer does not feed paper and display keeps saying paper jam
This is most likely cause by a paper jam in the printer. Simply open the printer up and remove and paper jams then reassemble the computer. I hope this helps and have a nice day!
May 03, 2011 | IBM Infoprint 1312 Laser Printer
Printer paper is getting jammed What should I do?
First we have to have some drop of oil on to the support of the roller so that there must be a better lubrication and paper will be fine printed.
Mar 27, 2011 | Canon iP100 Portable Printer
Paper keeps jamming on my new canon pixma ip100. Can you help me?
Are you putting too much paper in? Also, is the paper positioned below the tab?
Mar 27, 2011 | Canon Office Equipment & Supplies
I keep getting a "paper jammed" message, but there
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 25, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Jun 12, 2008 | HP LaserJet 2420 Printer
Canon iP100 Portable Printer  Logo
799 people viewed this question
old marine
old marine
