Question about Nokia N73 Cellular Phone
How to fit a n73 fascia - Nokia N73 Cellular Phone
How to i remove the factory stereo from a 2002 honda accord
1) Pry out the clock with a fine screwdriver, it has no screws, take care not to mar the fascia, disconnect both plugs.
2) Take out the radio/ ac fascia by unscrewing the screw that was hidden behind the clock, and the 2 screws at the bottom of fascia
3) Take out the factory radio by unscrewing the whole chassis that supports the radio (4 screws at the corners) . Most stereo replacements will fit into this chassis too. Unplug the connectors, and the antenna plug.
Avoid cutting the cables. Use plug converters whenever possible. This will avoid speaker polarity problems, as well as night lighting, power antenna, memory power feed mix-ups .
4) Dismount the factory radio from the chassis (tray?), in order to reuse it.
Mar 03, 2011 | 2002 Honda Accord
Need to allocate relay for the wipers as theyt wont turn of audi a4 se 1999
The wipers relay is placed in the fuse box / relay plate, fascia 2, inside the car above pedals on driver's side. See pictures below:
Fuse box / relay plate, fascia 2 (red point)
The wipers relay is no.# 5 (or no.# 6 depending on vehicle specification), placed in the fuse box / relay plate, fascia 2
NOTE: Location 1-19 - these relays are fitted to any vacant position during assembly, depending on vehicle specification.
Please do rate my response. Thanks!
Dec 20, 2010 | 2002 Audi A4
How to fit blacberry 8900 replacement key pad
dead easy! you will need T4/T5 screwdriver bits to take out the screws, once you have done that prise off the black clip at the bottom of the blackberry (just below the catch for the battery cover) to reveal 2 more screws, take them out. take the rear fascia off (little clips on the side) you will see the keyboard fascia unplug everything carefully from it and replace. try youtube for a detailed video on how to do this. Its very simple! Hope this helps.
Mar 31, 2010 | AT&T Blackberry Curve 8300 Smartphone
How to change radio on Almera X reg? Does it take a lot of force to remove original fascia panel?
Did a bit of googling and found this site which showed everything in perfect detail.
http://www.fitaudio.com/?View=entry&EntryID=58
Problem solved! Needed a new fascia panel [which I'd had for a while] and wiring adapters for the new radio/cd but these were easy to get from eBay and Halfords.
In retrospect it would have been less hassle just to have got it fitted professionally.
Wife is all smiles now that she can throw her pile of cassettes away.
May 23, 2009 | Car Audio & Video
Door will not close
Door Latch can be changed easily.Remove fascia panel screws,and latch cover screws;ease fascia panel forward slightly to enable unhooking of spring.Carefully remove latch and fit new part(£7-50 from Lehhmans at Stoke on Trent.).Do not bend contacts.Refit all screws.Job Done.(10mins)
Aug 17, 2008 | Canon EOS Elan IIE 35mm SLR Camera
Damage
Here is a replacement Fascia:
http://cgi.ebay.co.uk/Original-Samsung-F300-Housing-Cover-Fascia-Brand-new_W0QQitemZ140207015445QQcmdZViewItem?hash=item140207015445&_trksid=p3286.c81.m20.l1116#ebayphotohosting
Kind Regards ACD
If you need it fitting please reply
Mar 14, 2008 | Samsung SGH-F300 Smartphone
Fitting a new fascia
hi goto to
http://repair4mobilephone.org/cell_phone.html
and download a how to video
regards
mrjazon
Oct 29, 2007 | Nokia N80 Cellular Phone
Nokia N73 Cellular Phone Logo
26 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
