Question about Pool & Spa
Hello Pump is making loud noise and i am betting its the bearings, where can i get them and is it hard to change?
    President:
  • 1,378 Answers
If you are at all mechanically inclined changing them is not to difficult. Look in your local yellow pages for a bearing distributor or power transmission distributor in your area. Placed like Motion Industries, Bearing Service, Applied Industrial, etc. Most spa/pool pump motors use 6203 sealed bearings but your old ones should have enough on them that if you pull the rotor and take it with you you'll walk out with what you need.
Posted on Dec 10, 2009
  • John Prohaska
    John Prohaska Dec 10, 2009
    BTW - replace the pump seal while you are at it...the same place should carry those as well.
FLC271W2 washer squeal during wash cycle
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
May 23, 2014 | Frigidaire Washing Machines
Pool pump makes a loud noise
bad bearings change pump and motor
May 14, 2014 | Waterway Impeller Pump 2HP SD WW
Entering test mode
1) try to go the instr. manual and go to the section troubleshooting they explain this . However if you do not have it download from .
www.manualslib.com
see this causes and fix it.God bless you
Tub Bearing If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced.
Tub Seal and Bearing Kit If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem and the parts are relatively easy to replace.
Rear Drum with Bearing If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley If the washer is making a loud noise the pump may be worn out, or something might be caught in it. Remove the pump and inspect it for debris. If it is clear and the blades spin freely the problem might be somewhere else.
U-Joint Kit If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch Assembly If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the
Drain Pump If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Drive Motor If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault. Replace it.
transmission it may have to be replaced.
Sep 30, 2012 | Washing Machines
Was making loud noises on the spin cycle,now quiet but don't spin
the noise was obviously the loose change ( always check pockets ) lol. if still making noise, just replace the pump, its easy enough to do
Dec 21, 2011 | Frigidaire GLTF1670A Front Load Washer
I took my 2005 Chev. Malibu in for an oil change and now it is making a loud noise from the engine. they say its the water pump? is that possible?
  • Hi, I can help.
  • When your water pump goes bad it will begin to grind. I had one I let got far to long and it sounded deafening when I opened the hood. You can open your hood and listen and see for yourself. The water pump is on the belt line, left side under the hood, last pulley toward the rear.
  • Now if your asking can an oil change effect the water pump? No, not at all. Water pumps go sporadically.
  • It would be odd that you heard no noises before the oil change and now the water pump is loud enough to take notice after the oil change. The bearings usually go a little slower than that.
  • I would be interested in some more of the details to this. And what your overall concerns are. I'd be happy to further. help. Otherwise get a second opinion on your cars condition.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 22, 2011 | 2005 Chevrolet Malibu
Machine makes a loud noise when it tries to pump
this is not a bearing problem.it could be just be a blockage in the pump or the hose coming from it.
Oct 24, 2009 | Washing Machines
Power steering making loud noise/harder to turn wheel
Hello, from the sounds of it your power steering pump is going bad. Two things to check is one, pull off the cap and smell the fluid to see if it smells burnt. If it does you will need to change the power steering pump. Another thing to check is to make sure the belt is good and snug that runs the pump, the noice could be the belt slipping. You may need to tighten it or change it depending on how it looks. I'd check the belt first as that is the cheaper fix.
Mar 31, 2009 | 1992 Chevrolet Camaro
Fisher-Paykel washer pump noise & some water left in tub
Lube the brass bearings on the motor. For some reason the bearing on the bottom nearest to the cooling fan will start to whine. I would guess because it's kicking dust up around the unit. I used a lube that will hold in place. Lube between the bracket that holds the motor together and by the fan. The noise should stop. I also suggest you lube the top bearing as well. The lube I recommend is a Silicone paste type.
Jan 04, 2009 | Fisher Paykel EcoSmart GWL15
1993 mercury topaz GS Engine noise
Another guess would be the water pump going bad. That noise can be loud when it gets pretty bad and makes like a metal on metal grinding noise
Nov 06, 2008 | 1993 Mercury Topaz
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Pool & Spa Logo
188 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
