Question about Cuisinart Brew Central 12-cup Coffee Maker
The inside of our coffee pot is stained, how can I clean it
All you have to do is fill the coffee pot (to the top with hot water and add some automatic dishwasher soap. Let it sit and ALL of the stains will come out...like magic!
Posted on Dec 30, 2009
    President:
  • 704 Answers
Hello Doggylvr! There are lots of commercial products that will clean your coffee pot, but I've found that the least expensive and just as effective method is to do the following:
Take some plain table salt and put about 1-2 tablespoons full into the dry, glass coffee carafe (pot). Now add it a bunch (10-12) ice cubes.
With the lid on, swirl the pot around so the ice and salt gets at the sides and bottom. I find that doing this over the sink is best, as I turn the pot on it's side while I hold the lid in place and swirl the ice/sale mix until all the sides are "scrubbed" with the non scratching mix.
This will loosen and dislodge the oils from the coffee without damaging or scratching the glass pot. Scratches in the pot can cause it to break, so when you're all done, use a plain sponge to wipe the inside out to get any stains left.
Rinse with cool water a few times and you'll be back to fresh tasting coffee in no time. If you've really got some serious staining, you can add a little white vinegar to help attack the stains, but I've found that the salt and ice works just fine.
Hope you find this Very Helpful and best regards!
Love the name (Doggy Lover!)
Posted on Dec 10, 2009
  • Mark
    Mark Dec 11, 2009
    If by chance, you were wondering how to clean the water reservoir, just use a 50:50 mixture of water and white vinegar and fill the water reservior and run a brew cycle to clean out the water tank. I typically use a clean paper filter so I can see how much gunk (technical term!) comes out of the coffee maker, so I can decide to run anothe cleaning batch or not.
    When your done with the cleaning brew mix, just run two (2) clean water cycles (to flush out the vinegar so your coffee won't taste terrible) and you should be all set. I usually clean the water tank a couple of times a year.
    Hope this is Very Helpful and Merry Christmas!
You can use the vinegar method or if you want to use a commercial product, my favorite is Whink Coffee Maker Cleaner. I get it at the grocery store in the coffee isle. I have used it for over 20 years and find it the best and least expensive brand. I used to sell coffee makers, retail, and this is the brand that most reps recommended. You just have to run clean water through a couple of cycles after cleaning.
Posted on Jul 14, 2012
3 Suggested Answers
SOURCE: coffe residue inside coffee pot
Add some automatic dishwasher detergent ( maybe 1/4 cup) and fill the rest of the pot up with very hot water. Swirl to combine. Let stand for a few hours. Use a bottle brush to scrub the pot. Or get some denture cleaner tablets and throw them into the pot with hot water. Let stand a few hours or overnight, then scrub with bottle brush. I've tried both methods on my coffee pot and both work great for me.
Posted on Sep 27, 2009
  • 396 Answers
SOURCE: Coffee overflows onto the counter from time to
I believe your problem is the filter basket holder is not seated correctly or the carafe is not completely inserted in the unit to push the brew pause lever up. The brew pause feature which stops the coffee from going into the carafe when you want a cup of coffee before the brew cycle is done. When you remove the carafe a spring lever stops the coffee from dripping into the carafe. When the carafe is inserted it must push the spring lever up to allow the coffee to flow into the carafe. If it is not the coffee will overflow and make a mess. The filter basket holder should be firmly seated in the unit so it will not have any play in it. Cuisinart recommends using a vinegar and water mixture but BrewRite Cleaner (Sodium Carbonate) available in the coffee section at Wallmart, Kamart and Target is fantastic. You can clean your carafe with BrewRite Cleaner and hot water by letting it soak a few minutes and rinsing. I will also clean your filter basket holder by soaking it as well and all your coffee residue will be gone with no scrubbing.
Posted on Jul 29, 2010
Cleaning
Check bunn.com for a free download of manual with maintenance instructions.
* In general;
-Keep the area clean by wiping down with a damp clean cloth.
-Remove the brew funnel and wipe spray head of coffee and grit.
-Wash the brew funnel after each use.
-Dump out old coffee and wash pots after closing. Heavy coffee stained pots can be filled with plain water and soak over nite. Rinse clean before using.
-For extreme caked on dried coffee pots; fill with hot water and leave on warmer over nite. Ask vendor for URN cleaner and add a tablespoon in pot with hot water. Let sit over nite on warmer plate. Rinse clean prior to use.
-Check if everything is working properly. Better to call and leave a message for service.
* when in doubt, call vendor for service.
Aloha, ukeboy57
Mar 06, 2014 | Bunn Coffee Makers & Espresso Machines
How can I get the coffee stains out of my fine bone china pot?
Repeated coffee drinking in fine bone china can cause staining that doesn't come out with the regular gentle washing. To get these stains out you need to mix baking soda with some water until you create a paste. Spread the paste onto the cups until the stains have disappeared. Then rinse them out with soap and water.
Feb 27, 2013 | Home
Cleaning the staining & coffee from a one-year old 4 cup coffee pot.
You can try salt and ice. Try pouring about a tablespoon of salt into the pot and a couple ice cubes. Hold the pot by the handle and swirl it around in a counter clockwise direction allowing the ice to move around the inside of the pot. Don't do it too fast, you could break the pot.
Sep 19, 2011 | Computers & Internet
Coffee has a tangy flavor
You need to clean the coffee maker.Use white vinegar.Just fill the reservoir with and hit brew.When it is done.Fill the pot half way with ice and one hand full if salt.Swirl the pot till all stains are gone.Then run one full pot of clean water,to rinse.Make yourself a fresh pot and enjoy.
May 16, 2011 | Keurig B60 Coffee Maker
Pot is stained on the inside
Hi Staffordai:
I have had great sucess with professional engine degreaser for removing coffee stains from glass and plastic.
If you have water salt staining (white crust) then try acids that work on your shower head such as CLR.
Remember to flush 10 times more than you think is reasonable.
Good luck,
Bob
Feb 21, 2011 | Braun AromaDeluxe KF 510 Coffee Maker
The water isn't fully coming out when brewing a cup of coffee and won't fill the cup. I am maybe getting 1/4 cup of coffee
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 15, 2010 | Keurig B70 Coffee Maker
I have water draining back into the reservoir. It has been descaled and the needle openings have been cleaned.
Oct 14, 2010 | Keurig B60 Coffee Maker
Inside of carafe changing color -- is it still safe to use? (have been using it for 6 years)
The owners manual with our "12 cup Barista aroma grande" recommends cleaning the unit with a cleaner / descaler that you can buy at Starbucks, or 6 cups of a 50-50 vinegar-water solution, or 6 cups of a 50-50 lemon juice (no pulp!)-water solution. You have to then run a whole pot full of water through to rinse the unit. My wife cleans it once or twice a year with the Starbucks cleaner, and the staining comes off the inside of the pot (you may have to do it more than once with a 6-year deposit). The coffee also tastes better afterwards - less heavy and oily, more crisp and flavorful.
Feb 11, 2010 | Starbucks Barista Quattro Coffee Maker
Coffe residue inside coffee pot
Jan 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Open Questions:
See all Cuisinart Brew Central 12-cup Coffee Maker Questions
Cuisinart Brew Central 12-cup Coffee Maker Logo
187 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Marvin
Marvin
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
