Question about Moen & One Handle Tub & Shower Faucet
I have a moen bathtub faucet with one handle. My problem is that when I rotate the handle to the hot side the water flow stops. How can i get hot water to flow?
  • 94 Answers
You may have problem with your cartridge . you will have to pull it and take good look at it and look in the valve body to make sure no debri s is blocking the water port's
Posted on Apr 24, 2010
I purchased a Moen L82691SRN "shower only" fixture. I hooked it up and can only get cold water to come out of shower head. When I turn the handle to the "hot" side it will only trickle...
You have purchased a scald guard faucet, that you will have to set for your own house. If you take off the handle and face plate and look down there should be a plastic part (usually a deep blue) with teeth. It restricts the hot water side of the unit. If you pull it out and rotate (about halfway) you should have water flow. If it is still not hot enough rotate it more, or less.
Jun 26, 2011 | Moen Home
I get hot water but no cold water from my moen one hand tub fixture.
pretty sure that model has shut-off's/stop's.they are on either side of the center of faucet,they take a slotted screw-driver.check that,and the balancing spool could be clogged,if the stop's are open check the cartridge real good,as well as the faucet body for any debris. if you end up pulling the cartridge flush out the valve body to prove flow from both hot,and cold.
Feb 18, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Bathtub single handle faucet had not been used for a few months. Now when you rotate to hot water posiiton, there is no flow. Cold is normal. Hot water works fine at nearby sink & otherwise. Did an...
yes, and hopefully piece's of the cartridge's rubber have not come off and lodged in the water port's.have had this problem quite a few time's.remove your cart' and while it's out, run water to flush out the valve body.shine some light in body before re-assembly.
Dec 23, 2009 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Cold water works, hot does not
your problem can be fixed by running a loop in the plumbing. If you hired a professional in the first place it would already be done. basically the water pressure isn't enough, i bet your faucet is on the second or third floor, or even just THAT far from the water heater.
Sep 07, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
My Moen kitchen faucet stopped working suddenly in that only a thin stream of water would flow at most when I turned on the hot water handle or the cold water handle to the maximum positions. I replaced...
wow... I wish you hadn't gone thru the expense of replacing the faucet... it's perfectly good... your problem was the aerator, it unscrews at the tip of the water spout and had collected too much sediment which eventually blocked water flow. Often happens quickly after your water is shut off at the main valve. Aerators cost about 50 cents...
Aug 30, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
Not alot of hot water?
1st Check the temperature restricting coller behind the cover under the handle. It is used to restrict the flow of hot water to stop you from being scaulded.
2nd Those set screws will control the flow. Check to ensure both sides are open the same amount of turns. If the water pressure is good turn in the cold side.
Jan 08, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen & One Handle Tub & Shower Faucet  Logo
208 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
