Question about GE Washing Machines
Ge Eight Cycle Washer (G-162 under lid) We have
Ge Eight Cycle Washer (G-162 under lid) We have had this washing machine for 14 years. The spin cycle is not draining on any setting. Went out last night mid load. Had to manually drain and wring out the clothes. Is it worth trying to fix?
SOURCE: kenmore he2 front load washer
I had the same draining problem as described by others, but the drain pump filter was not plugged. Instead, a large rubber band had somehow gone through the filter and was caught in the pump propellers. In my model (110.46472501), the pump can be turned and then pulled off of the filter apparatus by depressing a tab as the pump is turned (although I only learned this after taking out the pump and filter apparatus together), and the pump can then be cleaned. A perk in taking off the toe panel: attached to the inside of the panel was a trouble-shooting guide "for service technician only" which does include checking the drain pump filter for this problem.
Posted on Apr 20, 2008
ngfam1
  • 639 Answers
SOURCE: whirlpool washer not spinning or draining
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
took off the screw clamp and it had a sock in it. works great now thanks
Posted on Nov 08, 2008
TheMobilian
  • 8220 Answers
SOURCE: GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
It could be anything from a bad belt to a bad clutch to a bad tranny. In my opinion this washer is not worth repairing.
Posted on Jan 09, 2009
Washing machine will not spin
Hello there,
Ok, first check under the lid, there is a peg that goes into the top edge of the washer. That is a switch. The idea between this is that it is a safety feature for mostly kids, so that when the washer is on that high speed spin cycle, that a child does not open up lid and stick there arm or hand in and have it injured. Most washer are designed so that the washer will only spin when the washing machine lid is down. So, of course you have it down, but sometimes the lid might have got a little bent or warped. So first try with lid down pushing down on lid while on spin cycle. If still wont spin, most likely it is that switch that that peg goes into, if you take a knife or flat head screw driver, with lid up on spin cycle and push into that hole with the knife or flat head screw driver and do not here a click when pushing it and releasing it, then you need to replace that switch, it is pretty cheep, normally under 20 bucks and a appliance store and when picking up the part they can tell you exactly how to replace it yourself, it is pretty easy and only takes a few minutes. Hope this helps. Mike
May 15, 2011 | GE Washing Machines
Spin cycle will not engage, however the timer will continue and start the machine at the next wash cycle
open the lid when it starts spin cyce, use a small screw driver or whatever you have that's small enough to fit in the hole under the lid that the tab from the lid goes into. try pushing it in that's a saftey swicth that prevents the washer going into spin cycle with the lid open. it's mostly that
Aug 16, 2009 | GE Washing Machines
My washer will not spin.
hi..the reason to this problem is probably due to the
lid switch.
check this out..
thank you..
kindly rate my response..
Jul 20, 2009 | GE WBSR3140DW Top Load Washer
Washer will not go into spin cycle
disconnect the drain line from the wall, place a bucket under the line as you lower it. Gravity will drain the tub.
clarkco
Feb 27, 2009 | GE WBSR3140DW Top Load Washer
GE WCSR2080B4WW - After wash cycle the washer does not spin and..
your washer must drain to spin.you may have a blocked or failed pump.you get to it thru the frount.use a putty knife between the lid and the frount ,push the springs.top comes up take frount off.pump has two hose .pumps white or tan smaller.God bless,tom
Jan 01, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
GE washer will not go to spin cycle or drain.
Possible lid switch not fully engaged. It will no drain or spin if lid switch is not fully engaged. I would also check the drain line for pluggage.
Oct 22, 2008 | Washing Machines
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Apr 17, 2007 | GE WJSR2070B Top Load Washer
Washing Machines Logo
490 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
