Question about Philips Magnavox 9P6034C 60" Rear Projection Television
UNABLE TO BRIGHTEN PICTURE
I HAVE HAD MY TELEVISION FOR ALMOST 11 YEARS, AND OVER THE LAST FEW MONTHS THE PICTURE SEEM TO HAVE GOTTEN DARKER AND UNABLE TO ADJUST COLOR. WHAT CAN BE MY PROBLEM. I HAVE BEEN TOLD TO GET RID OF TV, CAUSE IT WILL COST MORE TO SERVICE; AND I WOULD BE BETTER TO GET A NEW ONE
  • Philips Master
  • 8,617 Answers
Your CRT coolant needs to be changed. Thats whats giving you the dim picture. You can also clean the projection mirror on the inside this often helps. But the coolant will need to be changed to get back the bright crisp picture. Hope this helps.
Posted on Jan 20, 2008
Why is my picture darker than normal
It may be the backlighting has been readjusted by someone other yourself. Whenever you go on battery, I'm sure you've seen the screen darken a bit. This is the backlighting being turned down to save battery life. There is usually a blue function "fn" key that allows the user to brighten or darken the display. Look at the blue icons in the F1-F12 keys. The one to brighten the display looks light a sun and the one to darken the display looks a full moon eclipsed. Press and hold the fn key and tap the desired function key to brighten or darken the display.
Jan 13, 2012 | Toshiba Computers & Internet
Our tv has been getting darker and darker - we've tried to adjust brightness in menu and have it set to far right but its still too dark. Is there another adjustment to brighten the picture other than...
In many many cases this is an indication of a failing picture tube. The gun assembly in the neck of the picture tube is shorting. There is a fix, but this is surely last resort and the final cure may not provide a fix. Picture tube rejuvenation is not always successful. I would certainly opt for a new TV. Thanks for asking, and show a few hands of support!
Mar 13, 2011 | JVC AV-27530 27" TV
My picture is getting darker and I can't brighten it up enough . would all the lamps be going out or what ever power them up be going bad.Any voltage checks be performed??
this set is over 11 years old now. All RPTVs have three CRTs light guns that create's massive static electricity. if this sets lenses and mirror have never been cleaned, this is why its getting darker. there is probably a massive build up of dust/dirt and grime on the light guns and mirror. clean these and it will perform like new again.
Nov 25, 2010 | Panasonic PT-51SX60 51" Rear Projection...
Dark shadow-like vertical streaks thru LCD screen (Sharp)
Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
Color fading in picture
you need to replace the coolant in thr CRTs( picture tubes) Vert common problem in phillips. You can get the enitre repair kit at the following link which has the coolant and instruction CD for phillips coolanrt change. Heres the link its under the repair kit section.
http://servicemanuals.vstore.ca/
Jul 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture getting darker
The tv has a room light sensor,
shine a bright light at it , does picture get brighter?
other wise when it is cool open the bulb door , is it coated or blackened, Don't touch bulb at all.
and a heavy covering of dust on internal mirrors will cause the same effect.
you will need help to clean it.
Jan 26, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Picture quality
I think you are right about the backlight. You need to replace the backlight tube or, if you can, replace the TV. Good Luck.
Sep 13, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Picture is getting darker and darker
if the tv has never been service before you could have dust on the 3 tubes,this will decrease the brightness to the screen. try taking the front or back off & see if you can see the top of the picture tubes. remember to unplug the tv & to clean spray the cleaner on the colth , then clean the tup of the tube. never spary on the tube itself. hope this works for you.
Oct 22, 2006 | Panasonic PT-51HX40 51" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
143 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
