Question about Whirlpool GU2700XTSB / GU2700XTSQ / GU2700XTST Built-in Dishwasher
Dosn't take water
Start the dishwasher and the water doesn't flow into the dishwasher
    President:
  • 704 Answers
Hello Fsorich, Please check you water supply valve to make sure it is open all the way and hasn't been turned partially off.
Also, please remove the float and make sure it is clean on the inside, as a contaminated float won't float and thus signals the water valve to stay closed, as it thinks there is already enough water in the dishwasher tub. There might be a screw holding a cover over the float, so you may have to remove that to get at the float. It should be clean and should free of any buildup or residue. Also you can manually lift and lower the float while listening for the tell-tale "click" that lets you know that the float switch is working properly.
If that doesn't get things working again, you should then remove the lower access panel of the dishwasher, typicaly held on with a coupld of screws at the top section, just behind the door.
Take a look to make sure that the connector/plug going to the water inlet valve is connected, as sometimes they're loose and work themselves off over time, rare, but it does happen.
If that is OK, then the most likely issue is a faulty water inlet valve and that will need to be replaced. I wasn't able to locate your part, based on an incomplete model number. But you can check online at www.searspartsdirect.com and enter in your full model number to locate the replacement part.
Just remember to turn off the power to the dishwasher and shut off the water supply before you remove the faulty valve. Simply remove the water lline connected to the faulty valve and disconnect the electrical connection plug on it. Remove the mounting screws holding the valve in place and install the new valve, reversing the steps above. Turn the water back on, checking for leaks and restore power and you should be all set.
Hope you find this Very Helpful and best regards!
Posted on Dec 10, 2009
SOURCE:
Will not clean dishes
Sometimes because of water pressure the inlet valve doesn't allow enough water into the machine to satisfy the float switch so you don't have enough water to completely clean the dishes.Manufacturers install whats called a flow washer to control the flow of water into the machine in case of too much water pressure. What you can do is remove the flow washer from the valve itself to allow enough water to enter the machine. The other problem could be that the water is not hot enough. Some water heaters are set to 120 deg. to save on utility bills. To clean effectively the dishwasher water temp needs to be at least 160 deg. which is the temp restaurants use to clean and sterilize their dishes. Check to see if your dishwasher has a water heat switch on the control panel that will increase the water temp to 160 deg. If not just turn up your water heater temp. To check water flow just open the door when it is finished with the first fill right before it starts washing and check to see if the float switch is satisfied. You can check it by just pushing down on it and listening for a click. Either one of these should solve your dirty dish problem. Good luck
Nov 08, 2012 | Whirlpool Dishwashers
My Kitchen Aid dishwasher model kudIo1Ilwh3 STARTS UP THEN STOPS, i HEAR THE WATER RUNNING, BUT DOESN'T CLICK INTO THE NEXT CYCLE. aFTER 2 HOURS THE GREEN LIGHT DOES ON SAYS DONE, BUT DISHES ARE STILL...
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Oct 19, 2011 | Dishwashers
Doesn't pump water
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Thank You for using Fixya
Sep 14, 2011 | Bosch SRV53C03UC Built-in Dishwasher
Hi, I have an Ariston LL64 model dishwasher that doesn't complete a wash cycle. It gets so far and stops with the "crystal care" light flashing. Any ideas? thanks Barry
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If not the pump must be checked for clogging.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Aug 03, 2011 | Ariston Technologies LL64WNA Built-in...
Dishwasher water pumps in and out but doesn't move onto next part of cycle
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor .
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water .
For spares click On:
http://www.espares.co.uk/search/dishwashers/p/1083
Jul 18, 2011 | Asko Dishwashers
Intake/drain light keeps blinking and the dishwasher doesn't work.
Jul 13, 2011 | Miele Incognito G818SCVi Built-in...
When I start my dishwasher the check water light keeps comming on. Also the salt light so the machine does not go through its cycle. Can you please advise me the best course of...
Hi, if your unit is getting good water pressure then the problem is going to be your flow meter which is the device that measures how much water is coming into the unit. If it doesn't detect enough water coming into the unit, the dishwasher will hault and give you check water light error. When the error comes up look at the water in the bottom and see if you have enough water in the bottom for a cycle. If not then your flow meter is fine and your unit truely isn't getting enough water which means that either your house isn't giving good water pressure to the dishwasher, or the electronic water valve that connects to the water line from your house is bad and needs to be replaced....
Jun 21, 2011 | Bosch 18 in. SRS56L08 Logixx Slim-Line...
Dishes dosn't come out clean.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
May 17, 2011 | Dishwashers
Whirlpool GU2700XTSB / GU2700XTSQ / GU2700XTST Built-in Dishwasher Logo
65 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
