Lennox intermitent flame problem
I have a lennox furnace without a pilot lite, it will glow and the flame will start and then shut off immediatly, sometimes it works fine and then it has problems. The warning lights give me a warning that it didn't sense a flame, is this a flame sensor issue?
    Sergeant:
    Champion:
  • 215 Answers
Yes the flame sensor is not allowing the ignitor to start, you will need to remove the flame sensor, and clean the black carbon build up from the stem of the flame sensor, replace the flame sensor and turn the furnance back on, this will correct the problem.
Posted on Dec 14, 2009
Ignition failure.
if furnace fires up then immediatly shuts off check the flame sensor. make sure it is sitting far enough inside the burner box and has proper continuity. if ur getting ignition failure without having furnace fire up, check proper voltage to hot surface igniter, continuity within igniter
Dec 05, 2013 | Heating & Cooling
Lennox G20 gas valve switches off then on Intermittently?
This could be a dirty flane sencor of the pressure switch check hoses are tight and not spilt , try jumping out the pressure switch see if that makes it work also check air fliter is clean .
Feb 11, 2013 | Heating & Cooling
For some reason the heater does not generate heat. the fan works but no heat. Any Ideas?
I've got an easy way for you to check, and then we can help you from there.
First pop open both lids to your furnace (this may require a screwdriver). Turn up your thermostat, push the safety interlock button in if it has one (it's a button that turns off the power when the doors are removed), and watch.
On most modern furnaces (past 20-25 years) you'll hear/see:
1. Inducer fan
2. orange glow (ignitor)
3. Gas valve opening and ignition (flames)
4. Main Fan.
that's normal heater operation.
The most common issue here is a burned out ignitor, in which case you wouldn't see the orange glow but the sequence would attempt to continue anyway (the gas valve will open and hiss gas, but it won't lite, then it'll give up and try again a few minutes later).
On older furnaces there's a pilot light to start with, the click of the gas valve and boom... ignition.
On new furnaces it's
Inducer fan
gas valve opening
spark - ignition
Main fan.
and there are some oddballs in between, particularly the Lennox Pulse. If that's your furnace just back away slowly and call a professional... some guys won't even touch those, so be sure to mention what it is... if you call a pro.
So go ahead and watch it run, then tell me/us what you see.
May 06, 2011 | Bionaire Heating & Cooling
Gas Furnace - residential -found furnace off - pilot light off -
check ur venting first make sure its not plugged
Jan 01, 2010 | Heating & Cooling
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
Pilot light will not stay on
Sounds like the flame rod is not acknowledging flame. The rod stick up in the flame. Clean the rod and try again. thre could be other problems bad roll out bad limit switch or something in control circiut but start there. Rus
Nov 28, 2009 | Heating & Cooling
The exhaust blower starts for about 15 seconds then shuts off. several minutes later, the same thing happens - over and over
goodman furnance the exhaust fan starts, igniter glows hot, all burners lite up & will burn for about a minute and shuts down . I think it senses the room blower does not start so it shuts down.
Oct 20, 2009 | Ruud UBHC Air Conditioner
Furnace pilot light turns on furnace lights then shuts off
If you have a hot surface igniter (glow coil) it has a secondary purpose after ignition and that is to sense that there is actually flame present. If the HSI is located on one end of the burners look to the other and see if there is a small rod that protrudes in to the flame as well. If so it is part of this flame proving cycle. Take some sand cloth and clean it. This may buy some time but the rod should soon bee replaced.
Jan 17, 2009 | Heating & Cooling
Gas furnace wont stay lite
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Dec 16, 2007 | Heating & Cooling
Heating & Cooling Logo
464 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
