Question about Sony Playstation 3 (PS3) Console
Hi after resetting my ps3 on system settings on restore ps3 system afer turning it back on at the very start it asks you to connect ur controller with the usb cable and press the ps button however as i press the ps button nothing is happening and i cant do anything till the system recognises my pad my pad lights up it flashes 4 abit n then goes off how can i get back on my ps3?
  • 48 Answers
It sounds like your joystick won't pair up try turning on the joystick first then put the usb cord in
Posted on Dec 11, 2009
SOURCE:
My unit turned off during gameplay now i cannot turn it back on even to eject the game
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
Restart System: Restarts the PLAYSTATION®3 System.
Restore Default Settings: Reset all system settings back to default.
Restore File System: Checks for corrupt/missing system files.
Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
System Update: Update the PLAYSTATION3 System
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
My ps3 wont read games or movies
This comes from the Playstation Forum:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If it still doesn't work then your lens inside the PS3 needs to be cleaned. Here is a video tutorial that will show you how you can clean the lens inside the PS3:
http://www.youtube.com/watch?v=7O-8NzYHr80&feature=player_embedded
Jan 02, 2011 | Sony Playstation 3 (PS3) Console
Ps3 red light is blinking how can I fix it
• System Update: Update the PLAYSTATION®3 System.
Take care.
Aug 25, 2010 | Video Game Consoles & Games
I have my PS3 connected via HDMI tcable o a Sony
Hi, try and troubleshoot your cables and after doing that, you can try this out too.
You can try the steps below. Its from PlayStation Forum:
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
May 18, 2010 | Sony Playstation 3 (PS3) Console
Play station 3 won't play disc's r dvd's just stay's on home page!! What's the problem??
First thing to do is purchase a DVD laser cleaner and run that through the optical drive. If it still wont load your icons and freezes before your xmb, put the unit into safe mode and try restoring the filing system. To get it into safe mode, follow these instructions: hold down the power button while the console is in standby. The light will go from red to green and it will beep once and then flash green and beep again, and then beep a third time. after the third beep the light will turn red. once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finger off. The light will stay green and you'll get the screen asking you to connect the controller. After connecting the controller, try option 3, or whichever option is the "restore filing system" this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons (the xmb) You will also need to update your firmware, click on the link below to start this update:
http://us.playstation.com/support/systemupdates/ps3/index.htm
Apr 06, 2010 | Sony PlayStation Portable (PSP) Console
PS3 unable to switch from 720 to 1080 PS3 does not
if u go to system settings down to restore defualt settings you can reconect the controllers and reset the system to ur tv
Feb 16, 2010 | Sony Playstation 3 (PS3) Console
Ps3 will not display start up or allow any game or more to display ont tv?
Try a video reset on the system, turn the system off so just the red light is on then hold your finger on the power button till you hear two beeps and it shuts. Then turn the system back on. If this does not work try.
1- Disconnect the PS3 from the internet.
2- Turn the standby switch off so the red light turns off too, then you turn the system back on
3- Then place your finger on the power button for a total of 4 beeps to access the recovery menu. It might not work on the first attempt but it will on the second.
4- The display will instruct you to connect your controller to the PS3 and press the enter button. A list of menus will appear on your display. The choices are as follows: Restart System, Restore Default Settings, Restore File System, Rebuild data base, Restore PS3
5- Select Restore Default Settings.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Games will not load ps3
here is one of the best answers that I ran across in the past about said issue.
this is what i would do :
First of all, try playing all of your games and see if its just one disk or ur ps3, following that i would say u put in a blu-ray movie and check if that works, if it doesn't, then u are in serious trouble ( not really!). Get a USB Memory Stick( u know one of those little things u plug in a computer and can save all of ur stuff in) save ur important stuff. and then after that reset ur system settings, u can do that by:
Settings> System Settings> Restore System Settings
after that try it and if it doesnt work, go again to system settings but this time around, go to restore ps3 system, u can do that by:
Settings> Sysem Settings> Restore PS3 System.
it should be noted that all of ur stuff will be deleted, so i hope u saved all of ur game saves on that usb flash stcik thing.
if it doesnt work then do the following:
call sony:
SCEA Consumer Services
1-800-345-SONY (7669)
Monday - Saturday 6:00 AM - 8:00 PM PST
Sunday 7:00 - AM 6:30 PM PST
and tell them about ur problem, they will tell u to restore system settings or restore ps3 system, and thats what i told u, if it doesnt work, they will ask for ur adresss ( i hope u live in North America) and will ask u ur email, phone number and all that. After that they will send u a box( takes around 4-5 business days for the box to get to ur house, but it really matters where u live) and u put ur ps3 in that box, send it back, and then they will fix it, if they cant they will either send u a refurbished ps3 which is someone elses ps3 but dont worry its as good as brand new or if not, they will send u a new ps3. which will take sbout 4-5 business days, and again depends on where u live!
Aug 12, 2009 | Sony Playstation 3 (PS3) Console
Ps3 menu
Hi there. if you have PS3 Firmware 2.5 you could be in look. there is a System Restore ability on the PS3 which will allow you to restore your PS3 to a working state. and here is how to do it ! :
1. Turn off Playstation 3.
• Restart System: Restarts the PLAYSTATION 3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• System Update: Update the PLAYSTATION 3 System
hope this Helps !
Oct 26, 2008 | Sony Playstation 3 (PS3) Console
My PS3's hard disk file system is corrupted
This happened to my husbands PS3 also. He put it into another PS3 and reformatted it and then when he got home and put it back into his it asked him to reformat again and this did the trick. It's been working ever since. He called Sony and they wanted him to send back his hard drive and they would either fix or send him a "new" refurbished one for $150. I don't think so!!
Apr 22, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
239 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
